got this from Redscampi a while back. pretty cool buggy. made in 1985, 24 years old!!
any way it had the rear "blocks" broke that hold the axle in place (the part where it pivots)
he glued it,then i got it, slightest movents would fracture the glue "weld" , put the tires on and it just collapsed under its own weight. so i tore it down, was gonna modify it, install real electrics. never got around to it,so i kept it out of the packed up cars, and decided to get it going. it now has a rear axle from a tamiya hornet, them blocks are from a hornet, has a futaba servo,novack ESC, black can motor or open can or something. works great , just need to figure out how to fix the servo, its reversed, my radio dont have the reverse switch!!
has tamiya hornet rims and tires. this conversion did not require any cutting ,drilling. it was a "screw together" conversion. could be turned back to stock, youd never know it was modified. its a True "sleeper"
partial build vid , ill have a "how to " vid on to do this "conversion " if you got one of these laying around
http://www.youtube.com/watch?v=lS8H0AlD5ME (this vid is PG13, no vulgar stuff guys.sorry for the recent vulgarity)
Redscampi's old Nikko Frame Buggy Rhino , its Alive !!
- Banned Member
- vintage racer
Re: Redscampi's old Nikko Frame Buggy Rhino , its Alive !!
See if you can unscrew the steering gimble stick and spin in round.This is how I used to reverse the old Acoms radio back in the day.
Good to see that beast being used Matt! Good work.
Gary
Works for older futaba attack radios as wellvintage racer wrote:See if you can unscrew the steering gimble stick and spin in round.This is how I used to reverse the old Acoms radio back in the day.
- 800 Views
Last post by Dadio
- 1240 Views
Last post by tizeye
- 6699 Views
Last post by lee540
- 2510 Views
Last post by slapshot1979
- 2042 Views
- 1939 Views
Last post by Diggley
- 588 Views
Last post by Mad Racer
- 680 Views
Last post by THUNDERSTRIKE1
