My Kyosho Ultima Build
Hi, I am new to the forum, I'm in the Army so this may be a slow build, as of right now I am in transition and will be moving soon so I may not update with pics for a little bit, but just want to post what I have so far and my plans
Here is my Kyosho Ultima. I was maybe 6 or 7 years old when my dad bought it for me used from one of his friends. As a kid I was pretty hard on it, thrashed on it. I have have recently dusted it off, and regained intrest in it.
Since then I have tried to repair the thrashed body the best I could, and sprayed the outside with lexan paint so it looks ok until I get a new body for it.
Here are my plans for it
-RB5 Mod (thanks mikedealer for the info in your posts about it)
-RB5 front hubcarries, spindles, bearings and axles orderd
-RB5 Rear CVDs with the proline version axles
-Plan to mount Jconcepts rulux wheels with 4wd fronts
-Proline Rubber
-New top deck
-New body and cage
-New chassis (I cut some of it when I was younger trying to mod it)
-Install bearings throughout
-replace misc worn out parts
New electronics, maybe just a budget esc and a trinity monster motor with NIMH batteries to get it running again.
Any info on screw kits, and hopups for the era would be appreciated, and any sources for parts as well.
Please comment and post whatever, tell me if you think something wont work, or what you would recomend.
Please add to the list of known parts interchange for anyone with this similar project, let me know if I posted any wrong info, I just want to help. This was my first rc car and its great to start working on it again to continue the fun!!!
So far known parts to fit from what I have gathered
Tower Hobbies ST-15 (some parts identical) -if anyone knows exactly all parts that are the same please list them
Kyosho RB5 front axles/carriers/spindles for modern wheels in front
Kyosho RB5 rear cvds (not worlds)
-Proline Rubber
-New top deck
-New body and cage
Re: My Kyosho Ultima Build
Thanks Amain Hobbies!!! Ordered these on OCt 29th and got them today the 31st!! My kyosho is at my dads house back in Cali, and i'm on the other side of the US, so it will be a while before I can get to try to install these, but here are some pics I took.
These parts are:
Genuine Kyosho-
UM505
UMW507
Protek RC
5x10x4mm rubber sealed bearings
These parts are:
Genuine Kyosho-
UM505
UMW507
Protek RC
- m_vice
Looking good ace028, I started working on My Ultima last week and I am planning to do some of these mods you are doing. I want to see what you do on the rear.
Excellent car.
Excellent car.
Well, a quick trip to the hobby store and I found out that the rulux wheels don't fit. I think the other brands like Losi and AE front hex sizes for the 4wd fronts are like around 10mm. The Kyosho are 12mm, so I will be fitting some kyosho RB5 wheels or similar.
Thanks, I plan on trying to fit the RB5 Rear cvds on it, along with ST-15 Rear Hubs (I hear the ST15 hubs are a stronger plastic)
I will post more when I get some more progress, I will try to post all part numbers and brands for everyting to help anyone that wants to do the same mods.
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
- m_vice
ace028 make sure that the RB5 CVDs are not to long for the Ultima arms. You might have t use a different bone with the RB5 axel.
I like the st-15 arms, they look a bit custom.
Ok thanks, I will order the St15 rear arns when I order stuff from tower.
So the RB5 cvds may be too long? I guess I can measure the stock bone length and that should give me a idea if they will work right? I heard from Mikedealer that they should work.
- mikedealer
they work, ill take pictures of my rear setup when i have some time there, maybe later today
Thanks, that would be great!!!
Also do you know the part # for the kingpin that holds the spindle carrier to the knuckle for the Rb5 mod along with the retaining screws?
- Mr. ED
LOL you just answered the question I asked you on Oople.
And yes the RB5 CVD's fit well; just make sure you use the blue rings on the outside otherwise the axles will hit the drive cups under compression.
Mike; I don't know how the newer rb5 cvd's fit, any idea?
Well after taking a look at the RB5 exploded parts diagram, I found the kingpin shaft and the retaining screw part numbers, I ordered them from kyoshoamerica.com.
RB5 Front king pin shaft
-LA228
RB5 Front Kingpin shaft retaing screw
-1369 (pack of 10 2.5x5 button head screws)
I also ordered the servo saver set for the original ultima as it was only $4. They didn't have very many parts for the Ultima.
Ultima Servo saver kit
-UM14
This is probably it for now, will wait till next paycheck probably, unless the wife don't look lol.
-LA228
-UM14
- mikedealer
the st15 steering also works, and has a "servo saver" capability to it. the tubes work also for the st15. didnt get a chance to take pics of my rear yet but will
- Mr. ED
Yeah it can be a hassle if you have to do that on your own... maybe use a mirrormikedealer wrote:... didnt get a chance to take pics of my rear yet but will
bUWAHAAHAHAHahAHa unless he's got a lot of junk in the trunk LMAoMr. ED wrote:Yeah it can be a hassle if you have to do that on your own... maybe use a mirrormikedealer wrote:... didnt get a chance to take pics of my rear yet but will
2nd place is just the 1st loser
- 1286 Views
- 36 Replies
- 5319 Views
Last post by Sparbolt
- 41 Replies
- 10791 Views
Last post by Diezel
- 1863 Views
Last post by karnivool
- 19 Replies
- 6430 Views
Last post by Jay Dub
- 2029 Views
Last post by wydraz
- 4996 Views
Last post by aip47-2008
- 22 Replies
- 3847 Views
Last post by luckysaturn13
Users browsing this forum: No registered users and 16 guests
