Airbrush Compressor?
Post Reply
RC10WORLD
Post by RC10WORLD »
I need some help from you guys. I have a Sparmax AC-100 home in EU and I would like to find the same or a similar one in quality. Where is a good place to shop?
http://www.sparmax.com.tw/oil-less.htm
Many thanks,
Mannekenpis.
RC10WORLD
beardxxxd
Post by beardxxxd »
when someone that has knowledge answers the above
any reason why i cant use my garage compressor set at a low psi with a cheap airgun kit..
or will i get same results with a spray paint can?
RC10 Team
Has thanked: 28 times
Been thanked: 957 times
beardxxxd wrote:when someone that has knowledge answers the above
you could use an airbrush hooked to a shop air compressor, set at low pressure. if you would try to use a small spray gun at low pressure, it will not atomize the paint enough, do to the larger tip size. the paint will come out in drops, instead of fine particles.
an airbrush has a very small needle, and will atomize the paint efficiently at a low air pressure.
mrlexan
Been thanked: 10 times
Post by mrlexan »
Trust what Jason (Scr8p) knows, he sniffs fumes every day.
mrlexan wrote:Trust what Jason (Scr8p) knows, he sniffs fumes every day.
not intentionally. :wink:
knucklebuster
Post by knucklebuster »
scr8p, I have yet to try as I assumed it would be difficult to regulate low pressure. Any additional advice/specs on airbrush? Thanks.
i'm not much of an airbrush guy. most of my r/c paint jobs are easily done with a spray can.
i do have an airbrush. i've had it for years. i haven't used it too much. it's a single action aztec, i think. if you want a good one, look for a dual action airbrush. that way you can regulate the amount of paint and air pressure while you spray. just like a full size automotive spray gun.
that's about all the help i can give about airbrushes, specs wise. get a dual action airbrush. :wink:
knucklebuster
dual action... problem solved. Thanks scr8p.
fingerlakesrc
Post by fingerlakesrc »
I use a full size compressor for my airbrush which is dual action and it works great on small jobs. I use this in a sign shop plus paint r/c bodies.
RC10WORLD
Post by RC10WORLD »
Thanks for all your answers, I never thought about a full size compressor... looking for one now. :?
RC10WORLD
Post Reply
  • Airbrush and compressor help wanted
    by vwjuice » » in The Paint / Body Shop
    Last post by Johnboy72
  • Airbrush and Compressor Questions
    by RC104ever » » in The Paint / Body Shop
    Last post by twinrider1
  • Shop compressor questions
    by SteveK » » in Off-Topic / Chit-Chat
    Last post by SteveK
  • Let's see those airbrush stations!
    by XXWoodmanXX » » in The Paint / Body Shop
    Last post by morrisey0
  • Airbrush paint help
    by rwordenjr » » in The Paint / Body Shop
    Last post by Dadio
  • Airbrush not spraying
    by Mikeyboy » » in The Paint / Body Shop
    Last post by Mikeyboy
  • Airbrush recommendations
    by klavy69 » » in The Paint / Body Shop
    Last post by Vintagemishal
  • Playin With An Airbrush
    by Dadio » » in The Paint / Body Shop
    Last post by SoulKage
Users browsing this forum: No User AvatarGoogle Feedfetcher and 8 guests
