Inventory updates
Moderator: mytimac
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 54 times
Re: Inventory updates
2 updates tonight i guess.
A8004 JUNIOR 2 BUGGY BODY
A8008 XX BODY
A8014 LX-T TRUCK BODY
A8016 XXT BODY
A8017 XXT-CR TRUCK BODY
A8018 GTX BODY
A8020 CLASS 8 FORD TRUCK BODY XX4
A8022 NXT BODY w/WINDOW MASK
A8040 XXL BUGGY BODY
A8044 XX4 Body
A8045 "XX4""HW""BODY FOR HOT WEATHER"
A8050 STREET WEAPON BODY,WING & MASK
A8052 STRATUS FEAR SEDAN BODY SET
A8055 LEXUS IS300 SEDAN BODY w/MASK
A8060 DODGE STOCK CAR BODY w/ MASKS
A8062 FORD STOCK CAR BODY w/ MASKS
A8101 WING WIRE PRE-BENT FOR LOSI
A8102 ADJUSTABLE WING BUTTON SET
A8201 BODY SAVERS SNAP FIT
A8311 MACH.CUT XX LOGO SET(BUGGY) PINK
A8312 MACHINE CUT XX LOGO (YELLOW)
A8325 MACHINE CUT XXT LOGO (PINK)
A8326 MACHINE CUT XXT LOGO (YELLOW)
A8008 XX BODY
A8016 XXT BODY
A8018 GTX BODY
A8044 XX4 Body
- mytimac
- Business Member
Here is what has been put up today so far. A9300 and some A3000. Trying to get into the A4000 tonight and then A1000, A2000, and A97-A9900 Saturday if I can manage it.
A3001 TRANSMISION HOUSING (L&R)
A3002 MOTOR PLATE
A3003 GEAR DUST COVER (NON SLIPPER)
A3004 HYDRA DRIVE/SLIPPER GEAR COVER
A3006 DIFFERENTIAL GEAR (ONLY)
A3007 INTERNAL PRIMARY GEAR,SHAFT
A3008 DIFFERENTIAL ADJUSTMENT COVER
A3009 Differential Balls 3/32"
A3010 DIFFERENTIAL DRIVE RINGS
A3012 Differential Lube
A3013 MOLDED UNIVERSAL SET
A3014 UNIVERSAL PIVOTS
A3015 REAR AXLE,SPACER & PIN
A3016 REAR AXLE SPACERS
A3017 REAR OUTDRIVE SPACERS
A3019 WHITE SUPER SLIDER SHAFTS
A3020 BALL BEARING DIFF GEAR SET
A3021 BALL BEARING DIFF GEAR ONLY
A3022 TRANSMISION PINION GEAR 22T
A3023 OFFSET REAR AXLE SPACER SET
A3024 LOW FRICTION TANSMISION GEAR S
A3025 EXTRA LONG MOLDED DRIVE SHAFT
A3026 EXTRA LONG WHITE SUPER SLIDERS
A3030 NARROW REAR AXLE, SHIMS & PIN
A3033 XXX TRANS CASE SET & SPACERS
A3034 XXX TRANS SCREW SET
A3036 2.43:1 DIFF GEAR
A3040 MOTOR PLATE-NEON YELLOW
A3045 SLIPPER GEAR COVER PLUG
A3048 XXX GEAR COVER w/ACCESS
A3049 XXX MOTOR PLATE
A3054 XX RETROFIT TRANS CASES 2.19
A3055 RETROFIT TRANS CASES 2.61
A3056 XX RETRO SLIPPER SHAFT,SPACER
A3057 XX RETROFIT TRANS SCREW SET
A3058 TRANS CASE SET 2.19
A3059 TRANS CASE SET 2.61
A3060 SLIPPER SHAFT,SPACER & HARDWAR
A3061 TRANSMISSION SCREW SET
A3062 GTS TRANS SCREW SET
A3063 XX MOTOR PLATE
A3064 GEAR COVER & PLUG XX
A3070 XX DIFFERENTIAL DRIVE RINGS
A3071 DIFFERENTIAL THRUST BEARING AS
A3072 DIFF TUBE
a3074 DIFF GEAR ONLY 2.19:1
A3075 UPPER GEAR, ETC 2.19:1
A3077 UPPER GEAR,ETC. 2.69:1
A3078 DIFF SCREW,HARDWARE,SEAL SET
A3079 IDLER GEAR 2.19:1
A3080 IDLER GEAR 2.69:1
A3081 BUGGY DOG BONES/DRIVE SHAFT
A3083 YOKE & SCREW FOR DOGBONE/DSHAF
A3084 TRANSMISSION CASE SET GTX
A3085 GRAPHITE TRANS CASE SET GTX
A3086 SLIPPER SHAFT GTX
A3087 GTX TRANS IDLER GEAR
A3088 SLIPPER SHAFT SPACER(NXT & GTX
A3090 DOGBONE DRIVE SHAFT W/YOKE
A3095 XX MOLDED OUTDRIVE SET
A3096 UNIVERSAL PIVOTS FOR MOLDED OU
A3097 XX-4 MOLDED PIN DRIVE OUTDRIVE
A3098 Molded Thrust Bearing w/ Hard Balls
A3099 FULL COMPLIMENT THRUST BEARING
A3100 COMPLETE HYDRA DRIVE SYSTEM
A3101 HYDRA DRIVE UNIT ONLY
A3110 COMPLETE FRICTION SLIPPER UNIT
A3111 DOUBLE DISK SLIPPER CONV.KIT
A3112 HYDRA DRIVE FOR DOUBLE DISK SL
A3119 H.D.HOUSING SET
A3120 H.D.FRICTION SLIPPER SHAFT
A3121 H.D.FRICTION SLIPPER BACKING
A3122 H.D.FRICTION SLIPPER
A3124 H.D.FRICTION SLIPPER SPRING
A3125 9/16*1/4 THRUST BEARING ASSEM.
A3126 "HYDRA DRIVE FLUID ""STANDARD"""
A3127 "HYDRA DRIVE FLUID ""HEAVY"""
A3128 "HYDRA DRIVE FLUID ""LIGHT"""
A3130 HYDRA DRIVE UNIT REBUILT KIT
A3134 SLIPPER BACKPLATE/BRAKE DRUM
A3140 H.D. SHAFT W/GEAR FOR STEALTH
A3141 HYDRA DRIVE GEAR COVER FOR STEALTH RC10
A3214 1-WAY CLICKER PULY & BELT ROLL
A3215 ONE-WAY/CLICKER SPRING-STIFF
A3217 4WD BEARING INSERTS & O-RINGS
A3218 XX-4 OUTDRIVE BEARING O-RINGS
A3219 XX-4 MOTOR MOUNT & SCREWS
A3220 NON-SLPR MAIN SHAFT W/HDWE-SDN
A3221 XX-4 SLIPPER SHAFT ASSEMBLY
A9303 FOAM PRE FILTERS
A9304 AIR FILTER BOOT
A9310 FUEL TANK 75 cc
A9312 FUEL TANK REBUILD KIT
A9313 FUEL TANK MOUNTING SET
A9315 "FUEL TUBING 24"""
A9320 ALUMINUM EXHAUST FLANGE
A9325 "SILICONE EXHAUST CONNECTOR 2"""
A9326 TUNED PIPE / MUFFLER
A9327 EXHAUST STINGER AND SLEEVE
A9328 NXT TUNED PIPE/MUFFLER
A9330 PIPE MOUNTING BRACKET
A9335 MOTOR MOUNT SET
A9360 CLUTCH SHOES (GTX) TEFLON
A9362 MACHINED CLUTCH SHO & SPR NXT
A9363 SPRING FOR MACH CLUTCH SHOES
A9365 CLUTCH SPRINGS (GTX)
A9369 CLUTCH NUT & SPACER
A9370 CLUTCH RETAINING CLIPS
A9372 FLYWHEEL & PINS (GTX)
A9375 FLYWHEEL PINS - SCREWS
A9376 FLYWHEEL COLLET & SHIM
A9380 17 TH CLUTCH BELL
A9389 20TH CLUTCH BELL w/74T DB-DISK
A9402 GRAPHITE BRAKE ARM & PAD (GTX)
A9405 BRAKE/THROTLE LINKAGE SET
A9406 THROTLE SERVO ARM 23 SPINDLE
A9407 THROTTLE SERVO ARM 25 SPINDLE
A9408 SERVO MOUNTING SET
A9409 THROTTLE RETURN SPRING&EYELET
A9411 DISK BRAKE REBUILD KIT XXXNT
A9412 ALUM. BRAKE CLIPS XXXNT
A9413 DISK BRAKE ROTOR XXXNT
A9415 SERVO MOUNTING SET XXXNT
A3002 MOTOR PLATE
A3072 DIFF TUBE
- mytimac
- Business Member
Last of A3000 up and most of A4000
A3222 XX-4 FRONT SLIPPER BACKPLATE
A3223 XX-4 REAR SLIPPER BACKPLATE
A3225 XX-4 LAYSHAFT
A3226 LOWERED MOTOR MOUNT WITH SCREW
A3230 XX-4 FRONT DOGBONE & DRIVE SHA
A3233 FRONT DOGBONE W/BRG CROSS
A3236 XX-4 FRONT DRIVE YOKES & SCREW
A3238 TOP SHAFT SET w/HARDWARE XXX-S
A3239 BELT TENSIONER,POST & HARDWARE
A3240 XX-4 BELT ROLLER SHAFT & SHIMS
A3242 XX-4 SLIPPER SPRING SET
A3245 ONE-WAY FR DRIVE ASSEMBLY:XXXS
A3246 ONE-WAY OUTDRIVE CUP w/PIN XXX
A3247 ONE-WAY HUB w/BB L:XXX-S
A3248 ONE-WAY HUB w/BB R:XXX-S
A3250 FRONT SPOOL PADS XXXS G+
A3251 SHORT REAR DOGBONE SEDAN
A3255 SHORT REAR AXLE SEDAN
A3259 SEDAN WHEEL HEX ADAPTER
A3260 WHELL HEX DRIVES-STD AND METRI
A3265 SLIPPER REBUILD KIT XXX4
A3269 SLIPPER DRIVE PULLEY XXX-4
A3277 H.D. DRIVE BELT KIT XXX4
A3904 HYDRA 84T SPUR GEAR
A3906 HYDRA 86T SPUR GEAR
A3908 HYDRA 88T SPUR GEAR
A3910 HYDRA 90T SPUR GEAR
A3912 32P SPUR GEAR 51T XXXNT
A3914 74 TOOTH 32P SPUR GTX
A3915 75 TOOTH 32P SPUR GTX
A3916 SPUR GEAR 76T 32P GT-X
A3928 88T 48PITCH SPUR FOR DUAL DISK
A3929 86T 48PITCH SPUR FOR DUAL DISK
A3930 XX-4 84T SPUR GEAR
a3932 78 tooth 48 pitch spur gear xx4
A3933 76T SPUR GEAR 4WD BUGGY
A3936 84T SPUR GEAR 4WD (SEDAN)
A3937 82T SPUR GEAR 4WD SEDAN
A3939 78 TOOTH SPUR GEAR SEDAN
A3940 76T SPUR GEAR 4WD SEDAN
A3944 86T 48P SPUR w/DRIVE PULLEY:XS
A3945 88T 48P SPUR w/DRIVE PULLEY:XS
A3946 90T 48P SPUR w/DRIVE PULLEY XS
A3950 108T 64P SPUR w/DRIVE PULLEY X
A3952 118T 64P SPUR w/DRIVE PULLEY X
A3954 128T 64P SPUR w/DRIVE PULLEY X
A3958 92T 48P SLIPPER SPUR GEARXXX-4
A3981 78T 48P KEVLAR SPUR XXX/T
A3982 PITCH 48 82T SPUR PROFILED
A3983 82T 48P KEVLAR SPUR XXX/T
A3986 48 Pitch 86T Profile Spur Gear
A3987 86T 48P KEVLAR SPUR XXX/T
A3990 PITCH 48 90T PROFILED SPUR
A3992 PITCH 48 92T PROFILED SPUR
A4001 FRONT BATTERY CUP
A4004 SERVO TAPE
A4005 FRONT TOP MOUNT MINI BUMPER
A4010 BATTERY STRAP SET
A4025 TRANSMISSION BRACE GTX
A4029 FOAM PAD FOR RX BATT GTX
A4042 JRX-T FRONT BODY MOUNT SKID PL
A4044 JRX-T REAR BODY MOUNT
A4045 FRONT BOTTOM MOUNT BUMPER/SKID
A4047 MOLDED CHASSIS BRACE JUNIOR
A4048 MOLDED FRONT,REAR SHOCK TOWERS
A4049 JUNIOR 2 SUSPENSION PIN SET
A4050 JUNIOR 2 TIE ROD/LINK SET
A4052 FOAM CHASSIS PADS
A4053 LONG WHEEL BASE ADAPTER KIT
A4055 LX-T ADJUST.FRONT BODY MOUNT
A4056 FRONT BODY MOUNT XXT
A4115 BATTERY HOLD DOWN X-LONG (XXT)
A4116 XXX BATTERY STRAP,PAD & FOAM B
A4122 XXX FRONT KICKPL.BULK,& STEER
A4123 GEN II MOTOR GUARD & BODY MTS
A4124 XXX FRT SPINDL./CARRI.&RE HUBS
A4125 FR SPINDLES,CARRIERS,HUBS T-NT
A4126 XXX FR & REAR PIVOT BLOCK SET
A4127 FWD RE INNER PIVOT MTS BK2
A4128 REAR INNER PIVOT MT ALUM.BK2
A4129 PIVOT BLOCK FRONT ALL XXX/T/NT
A4130 FRONT BUMPER XX-XXT
A4131 FR BUMPER/SKIDPLATE XXX/T/NT
A4136 XXX FR & REAR INNER PIN BRAC S
A4140 SWAY BAR KIT XX-XXT
A4141 FRNT SWAY BAR SET/XX-CR,XXT-CR
A4150 STREET WEAPON SWAY BAR SET
A4160 KICKPLATE BLKHD BRACE XXXNT
A4208 CHASSIS COVER SET (XX4)
A4209 GEAR COVER & SCREWS :XXX-S
A4211 CHASSIS COVER SET SEDAN
A4216 MOTOR MOUNT CLAMP XXX-S
A4218 FRONT & REAR BUMPER SET SEDAN
A4219 FR & R BUMPER SET XXX-4
A4220 XX-4 BATTERY POST HOLD DOWN SE
A4221 BODY,WING,ANTEN,MOUNT,POSTXXX4
A4222 XX-4 WIG MOUNT SET
A3225 XX-4 LAYSHAFT
A4004 SERVO TAPE
- mytimac
- Business Member
A2000 are up now.
A2001 REAR BULKHEAD
A2003 HUB CARRIER REAR
A2005 REAR CAMBLER LINK W/ENDS E/LXT
A2006 "SWIVEL SUSPENSION BALLS .250"""
A2007 HINGE PIN(HUB 5-LNK)F/INER XXT
A2008 INNER HINGE PINS BULKHEAD
A2009 SEE #A4048
A2010 WING TUBES
A2012 ASSEMBLY WRENCH
A2014 H-ARM REAR CONVERSION KIT
A2015 H-ARMS SET
A2016 REAR PIVOT SUPPORT SET (4 PCS)
A2017 R-PIVOT PIN SUPPORT/ALL EXC-XX
A2020 PRO REAR SHOCK TOWER
A2022 H-ARM HUB CLIPS
A2024 REAR SHOCK TOWER SPACER SE,LXT
A2025 REAR HUBS ONLY H-ARM CONV KIT
A2031 REAR INNER HINGE PINS
A2033 Rear Hub Spacers for GTX
A2035 SE REAR SHOCK TOWER
A2036 REAR SUSP.PIN MTS 2 DEG (GTX)
A2037 REAR SUSP PIN MTS 4 DEG GTX
A2038 EXTRA RIGID REAR HUB (H-ARM)
A2040 LX-T REAR SHOCK TOWER
A2041 LX-T REAR SUSPENSION ARMS
A2042 GRAPHITE REAR ARMS (LXT-GTX)
A2043 REAR SHOCK TOWER GTX
A2044 NXT REAR SHOCK TOWER
A2047 NXT REAR PIVOT BLOCKS
A2101 REAR BULKHEAD XX-XXT
A2104 REAR BULKHEAD SHOCK TOWER 3XNT
A2107 CR REAR PIVOT PLATE
A2108 XXX REAR PIVOT PLATE
A2110 REAR PIVOT SUPPORT #2
A2112 Rear Pivot Block 0-Degree: CR
A2113 CR REAR PIVOT BLOCK 2 DEG
A2114 REAR PIVOT BLOCK XXXNT
A2120 REAR PIVOT SUPPORT #4
A2125 REAR HUB SET
A2126 CR REAR HUB SET
A2127 CR REAR HUB SPACER (.060)
A2128 RR HUB CARRIERS ALL XXX/4/T
A2130 REAR SUSPENSION ARMS XX
A2131 CR REAR SUSPENSION ARMS XX
A2140 REAR SUSPENSION ARMS XXT
A2141 CR REAR SUSPENSION ARMS XXT
A2142 REAR SUSP. ARMS XXXNT
A2155 REAR SHOCK TOWER XX
A2158 REAR SHOCK TOWER XXT
A2159 CR REAR SHOCK TOWER XXT
A2162 CR REAR INNER HINGE PINS
A2164 OUTER REAR HINGE PIN
A2166 INNER R HINGE PIN XXX/T/NT
A2201 REAR SHOCK TOWER XXX-S
A2204 XX-4 REAR SHOCK TOWER
A2205 REAR SHOCK TOWER XXX-4
A2206 REAR SHOCK TOWER XXX4 G+
A2207 REAR SHOCK TOWER SEDAN
A2210 XX-4 REAR PIVOT BLOCK & ANTI-S
A2216 XX-4 REAR HUB SPACER .050
A2220 REAR ARMS SEDAN
A2221 REAR SUSPENSION ARMS XXX-S
A2226 REAR HUB CARRIERS XXX-S
A2228 R HUBS 0 DEG. TOE-IN(ALL XXX)
A2230 REAR INNER PIVOT SUPPORT SET
A2232 R PIVOT SUPPORT SET XXX4
A2905 MONSTER DIFF MALE OUTDRIVE3XNT
A2909 MONSTER DIFF ADJ SCREW HARDWAR
A2911 ONE PIECE DIFF NUT/CARRIER
A2920 TRANS CASE SET,BRAKE CLIPS3XNT
A2933 GEN II DIFF.SCREW & HARDWARE
A2935 XXX-GEN II OUTDRIVE SET
A2937 IDLER GEAR,32T & SHAFT XX/GEN
A2940 GEN II TRANS SCREW SET
A2941 MACHINED MOTOR PLATE:XXX BK2
A2943 XXX GEN II GEAR COVER w/PLUG
A2001 REAR BULKHEAD
A2009 SEE #A4048
A2010 WING TUBES
A2015 H-ARMS SET
A2125 REAR HUB SET
- mytimac
- Business Member
A1000 all up now. Next a bunch of pinions I forgot about. Losi and Trinity, hope to price them in a way you will all just want to throw them in with your order.
A0903 CR SUSPENS. UPDATE KIT XXT
A1002 FRONT SPINDLES & CARRIERS
A1003 FRONT BULKHEAD
A1005 FRONT AXLES W/NUTS
A1006 KING PINS (ALL EXCEPT LX-T)
A1007 BULKHEAD INNER HINGE PINS
A1008 FRONT OUTER HINGE PINS
A1009 CAMBER/LINK TIE ROD L/R THREAD
A1010 LONG FRONT SHOCK MOUNT
A1011 LONG L/R THREADED TIE ROD SET
A1012 PRO FRONT AXLES W/HARDWARE
A1013 SWEPT FRONT AARMS (SE)
A1014 SE FRONT SHOCK TOWER
A1015 LX-T FRONT SHOCK TOWER
A1016 LX-T FRONT SUSPENSION ARMS
A1017 LX-T FRONT SPINDLES & CARRIERS
A1019 GRAPHITE FRONT ARMS (LXT-GTX)
A1020 NXT FRONT SHOCK TOWER
A1101 XX FRONT BULKHEAD
A1102 FRONT BULKHEAD BRACE (XXT)
A1105 FRONT SHOCK TOWER (XX)
A1106 "FR SHOCK TOWER ""BK""LTD EDITION"
A1107 XXX FRONT SHOCK TOWER
A1108 FRONT SHOCK TOWER (XXT)
A1109 FR SHOCK TOWER XXXT XXXNT
A1110 XX Front Suspension Arms
A1111 XXX FRONT SUSPENSION ARMS
A1115 FRONT SUSPENSION ARMS (XXT)
A1120 FRONT SPINDLES & CARRIERS (XX)
A1121 FRONT 25D CASTER BLOCKS & CARR
A1122 FR SPINDLES & CARRIERS ALL XXX
A1125 FRONT SPINDLES & CARRIERS(XXT)
A1131 FRONT STUB AXLES & SCREWS (XX)
A1132 FRONT STUB AXLE W/SCREWS XX-BU
A1133 XXX FR STUB AXLES/SCREWS
A1136 FRONT AXLES (XXT)
A1141 PIN SET FOR FRONT BULKHEAD
A1143 INNER FRONT HINGE PINS (XX)
A1149 FRONT OUTER &KING PIN 3/32 XXT
A1204 XX-4 FRONT SHOCK TOWER
A1205 FR. SHOCK TOWER XXX-4
A1206 FRONT SHOCK TOWER XXX4 G+
A1207 FRONT SHOCK TOWER SEDAN
A1208 FRONT SHOCK TOWER XXX-S
A1211 FR SUSPENSION ARMS XXX-4
A1213 FRONT SUSPENSION ARMS (SEDAN)
A1219 XX-4 FRONT STUB AXLE & HARDWAR
A1221 XX-4 UNIVERSAL PIVOTS
A1229 LOW F&R ROLL CNTR PIVT BLOCK
A1230 FRONT PIVOT SUPPORT SET XXX-S
A1232 FR. PIVOT SUPPORT SET XXX-4
A1233 SPINDLE CARRIER BUSHING & H XX
A1510 SHORT STEER.SECTOR ARM W/SCREW
A1511 EXTENDED STEER.POST J-2,PRO-SE
A1512 STEERING POST FOR LX-T
A1514 GTX STEERING POST
A1542 STEERING & SERVO SAVER HARDWAR
A1601 STEERING SERVO MOUNT ASS(XX-T)
A1602 ADJ STRNG/SERVO MNT SET XX/XXT
A1610 STEERING HARDWARE SET
A1615 SHORT BALL CUPS & THREADED ROD
A1620 XXX STEER/SERVO MOUNT ASSY(MOL
- mytimac
- Business Member
All A9000 are up now. That is pretty much it for Team Losi Brand parts. As I have been going along prices on many things have been adjusted down. If you looked before I put them back in stock, there is a good chance the price is lower now. Very few things got a higher price. RPM and Trinity parts in the morning.
Check out the pinions I mentioned earlier in the Gear section. 64P 32P and some 48P
http://sabulatech.com/storefront/index.php?id_category=80&controller=category
A9701 XX FRONT ARMS GRAPHITE
A9708 XXT KINGPIN/BALL SET
A9709 XXT FRONT ARMS GRAPHITE
A9710 GRAPH FR SUSP. ARMS XXXT
A9713 GRAPH KICKPLATE,BULKHEAD &STEE
A9721 XXT FRONT SHOCK TOWER GRAPHITE
A9722 GRAPH FR SHOCK TOWER XXXT-NT
A9730 0 DEG. FRONT BULKHEAD (4WD)
A9732 4WD SPINDLES CARRIERS (3 DEG.)
A9734 GRAPH FR SUSP. ARMS XXX4/G+
A9735 GRAPHITE FRONT ARMS XX4
A9736 GRAPH FR ARMS XXX4
A9737 GRAPH FRONT SUSP. ARMS XXX-S
A9743 GRAPHITE FRONT SHOCK TOWER SED
A9744 XXX-S GRAPH. FRONT SHOCK TOWER
A9748 GRAPHITE FR PIVOT SUPPORT SET
A9749 GRAPH FR PIVOT SUPPORT SETXXX4
A9752 2 DEG GRAPH SPINDLE SET
A9753 4 DEG GRAPH SPINDLE SET XXXS
A9754 6DEGREE GRAPHITE SPINDLE
A9800 GRAPH RR ARMS ALL XX/XXX/4
A9801 XX REAR ARMS GRAPHITE
A9802 CR GRAPHITE REAR ARMS XX
A9805 XX 2.5 DEG.REAR HUB SET
A9806 CR 1 DEG.REAR HUB SET
A9807 R HUB CARRIER SET 1Dg XXX,NT
A9809 XXT GRAPHITE REAR ARMS
A9810 CR GRAPHITE REAR ARMS XXT
A9813 XX REAR SHOCK TOWER GRAPHITE
A9814 GRAPH REAR SHOCK TOWER XXX
A9821 XXT REAR SHOCK TOWER GRAPHITE
A9822 GRAPH R SHOCK TOWER XXXT
A9830 CR GRAPHITE PIVOT PLATE
A9833 GRAPH. REAR PIVOT PLATE BK-2
A9838 GRAPHITE REAR ARMS SEDAN
A9843 GRAPH./COMPOS.REAR SHOCK TOWER
A9844 GRAPHITE REAR SUSP. ARMS:XXXS
A9845 GRAPH REAR SHOCK TOWER XXXS
A9847 GRAPHITE REAR HUBS:XXXS
A9848 XXX-S GRAPH.REAR PIVOT SUPPORT
A9849 GRAPH REAR PIVOT SUPP.SET XXX
A9850 GRAPH REAR ARMS( LXT,GTX,NXT)
A9852 1/2 DEG GRAPH REAR HUB SET XS
A9853 1 DEG GRAPH REAR HUB SET XXXS
A9854 GRAPH. OFFSET RR HUBS XXXS/4
A9855 1/2 DEG.GRAPH. OFFSET HUBXXXS4
A9856 1DEG.GRAPH. OFFSET RR HUB XXXS
A9860 GRAPH.REAR SUSP. ARMS XXXS/G/4
A9895 GRAPH.BOTTOM CVR/STEER TUN./4
A9896 GRAPH FR & RE DIFF COVERS XXX4
A9897 GRAPH BOTTOM COVER SET XXXS
A9898 GRAPH. BATT. STRAP/DROOP GAUGE
A9899 GRAPH FR/RR DIFF.COVERS XXX-S
A9909 GRAPHITE BATTERY HOLD DOWN XL
A9913 GRAPH CHASSIS COVER SET-XX4
A99170 SHOCK MATCHING TOOL
A9920 XX LITEWEIGHT,POLISHED MOT.PLA
A9921 CENTERED MOTOR(PLATE),CONV KIT
A9924 XX BUGGY ALUMINUM DOGBONE
A9927 ALUMINUM REAR DOGBONES
A9928 MIP CVD FOR XXX-S
A9929 MIP ALUMINUM CVD'S (PR.) XXXS
A9930 XX ALUMINUM GEAR/SLIPPER SHAFT
A9932 XXT ALUMINUM SLIPPER/GEAR SHAF
A9935 ALUM.SLIPPER SHAFT w/HDWE-XX4
A9940 ALUMINUM HARD COATED SUSPENS.B
A9942 BEARING SPACER/WASHER SET BK-2
A9945 TIT.BALLSTUDS w/HEXHD .188
A9946 TIT.BALLSTUDS w/HEXHD .250
A9947 TIT.BALLSTUDS w/HEXHD .380
A9954 AL FR PIN BRACE BLUE XXX/T/NT
A9956 AL FR PIN BRACE H ANOD XXX/T/N
A9971 CVD ALUMIN. DRIVESHAFT ONLY3XS
A9980BK XXX MACH.MOTOR PLATE ANOD.BLK
A9984 CVD SET STL BK-2
A9985 CVD STL DRIVESHAFT BK-2
A9986 CVD REAR AXLE GEN II
- mytimac
- Business Member
All Trinity parts that will be put on store are up. The Evolution, Revovler, Switchblade, and Street Spec parts will all got eBay in small groups eventually. If there is a specific part for you would like you can send me a message and we can pull it out and put on store. The pan car stuff is just not popular enough to take all the time to import into store.
Also the TK3007 Trinity XX front Bulkhead will be sent to eBay at some point as well as the TK1016 Team Kinwald Mod Motor replacement body.
EV0065 4-40 Cap Screws (black)
EV0085 2” Body Posts
EV0086 Body Post Collars
EV0150 2-56 Button Head (purple)
4027 Brass Motor Spacer Shims (10)
4029 Phenolic Motor Shims (12)
4029B Phenolic Motor Shims (100)
4031 Mod Motor Bearing
4043 Alum Heat Sink Motor Spacer
4033 Motor Springs Heavy Tension
4065 Sportsman Motor Brush
4075 Serrated Laydown
4077 Full Silver Serrated Laydown
4120 Motor Sleeve (more torque)
4380NT Serrated Hard Brush
4383NT Silver Serrated Brush
4389 Copper Med Heavy Motor SPrings
4450 High Frequency Capacitors
4451 Small Purple Motor Heatsink
4452 Large Purple Motor Heatsink
4530 Motor Spring Posts
4533 Motor Rebuild Kit
6841 Super Speedway Mounts
6042 THREADED PLASTIC POSTS 2”
6043 THREADED PLASTIC POST 3”
6063 OFF-ROAD TIRE BALANCER
6064 ON ROAD TIRE BALANCER
6068 Lead Balance Tape
7022 Precision Reamer
9228 Speed Gems Armature 10T
d1055 Purple Socket Head 4-40 1/4
TK2012 Motor Can Dirtinator
TK3002 XX BUGGY FRONT SUSPENSION BRAC
TK3003 Trinity Kinwald XX Trans Brace
TK3004 Kinwald Shim Kit
TK3006 Countersunk Washers Silver
TK3008 TEAM KINWALD GTX FRONT BULK BR
TK3009 XX-4 REAR SUSPENSION BRACE
TK3011 GTX Rear Mounts
TK3012 GTX Rear Mounts
TK3020 Big Boy Motor Screws
TK3027 XX4 SW Motor Spacer Mount
TK3030 XX-CR/XXT-CR TRANSMISSION BRAC
TK3032 Xx4 Transponder mount
TK3040 Losi SW 64P Gear Adapter
TK3050 FLAT HEAD 4/40*1/4 (12 PCS)
TK3055 Kinwald 4-40 1/2 Socket Head
TK3051 BUTTON HEAD 2/56*3/8 (12 PCS)
- mytimac
- Business Member
Finally done! Ughh this was a major task. The RPM stuff is up. Tried to be fair on prices but avoid certain issues…
Now a freaking huge amount of pictures to take!
As mentioned earlier http://www.rc10talk.com/viewtopic.php?f=90&t=41731
7000 R.P.M. LOGO DECALS
7002 BELLCRANK SET rc10
7005 FRONT SPINDLE BLOCKS rc10
7007 REAR CARRIERS(STOCK NO TOE-IN) rc10
7010 SMALL PARTS TRAY W/MAGNET
7018 DELRIN SHOCK PIVOTS (8)
7020 ONE PIECE FRONT SUSP. MOUNT
7025 SPRING CUPS (4) rc10
7030 REAR ARMS RC10T
7034 REAR BULKHEAD(DYEABLE) rc10
7040 FRONT ARMS FOR TRUCK rc10
7044 RC10 FRONT ARMS KIT (TEAM CAR)
7047 STEALTH TRANSMISION BRACE rc10
7050 BATTERY BOX Jrx2 rc10
7060 RC-10 TRUCK WIDE FRONT ARMS
7065 LOW PROFILE REAR CARRIERS rc10
7073 SHOCK BODY & CAP WRH FOR LOSI
7078 SHOCK BODY & CAP WRENCH ASSO
7080 NYLON NUTS 4-40 OR 3MM
7082 NYLON NUTS 6-32
7084 NYLON NUTS 8-32 OR 4MM
7088 BODY - POST HOLE PUNCH
7092 REAR SUSP.BLOCKS(3-DEG.TOE-IN)
7095 WIDE REAR ARMS FOR TRUCK
7096 SLIPPER WRENCH (1/4 inc.) Associated Losi
7150 ULTIMA TO BLACKFOOT REAR ADAPT
7300 JRX-2 HEAVY DUTY REAR LINKS
7301 JRX-2 .050 TOE-IN REAR LINKS
7302 JRX-T HEAVY DUTY BELLCRANK SET
7305 JRX-T EXTRA WIDE REAR LINKS
7306 JRXT .050 TOE-IN WIDE REAR LNK
7310 JRX-2 HEAVY DUTY SPINDLE BLOCK
7311 GEAR COVER(DYEABLE) JRX2
7315 JRX-2 HEAVY DUTY SIDE BULKHEAD
7318 DELRIN PIVOT BALLS 0.250 (12)
7320 JRX-2 FRONT BUMPER
7325 JRX-T EXTRA WIDE SIDE BULKHEAD
7328 TOP SHOCK PIVOTS (4) Losi
7330 "JRX-2 FRONT BULKHEAD (+10""CAS)"
7335 R.P.M. INSIDE REAR HINGE PINS (2) RC10
7337 BLACK HEAVY DUTY ROD ENDS (12)
7340 JRX-2 FRONT ARMS STRONG
7350 JRX-T WIDE FRONT ARMS
7355 JRX-T EXTRA WIDE REAR ARMS CON
7365 ESC TRAY FOR LOSI MOLDED CHASS
7371 CUSHIONED BUMPER FOR LOSI "XX"
7375 FRONT SWEPT ARMS JRX2
7379 ONE PIECE CENTER LINK LOSI XX
7385 HEAVY DUTY FRONT CARRIERS JRX2
7500 FRONT BULKHEAD YOKOMO
7510 NYLON FRONT CARRIERS YOKOMO
7515 YOKOMO NYLON REAR CARRIER (LIGHTWEIGHT)
7520 FRONT BUMPER YOKOMO
7540 LONG REAR ARMS & CARRIERS YOKO
7550 REAR BULKHEAD YOKOMO
7560 WIDE FRONT ARMS YOKOMO
8003 Worlds Shock Tower
8015 REPLACEMENT NOSE BRACE TUBES
8017 REPLACEMENT REAR ARMS(NAR.CHS)
8019 REPLACEM.REAR CARRIERS(NAR.CHS
70807 NYLON NUTS 4-40 NEON YELLOW
70808 NYLON NUTS 4-40 PURPLE
73155 LOWER SPRING CUPS (LOS/TRA)BL
73360 SD ROD ENDS:LNS/SD
7100 OPTIMA TO BLACKFOOT ADAPTER
- mytimac
- Business Member
Seems like I had error importing some things. So might be little bit to get them fixed. I know 7340 didn't show. If in an hour you can't find one let me know.
oh never mind i just messed up on the RPM#### part of numbers they should all be there if you just search on the 4 digit number.
- mytimac
- Business Member
Moving stuff around today we found some more A8111 JRXT Dirt Shields and some A3004 Slipper Gear Cover(error version)
We haven't started production yet with our new machine. That should start the last week in June. All our equipment and parts to start running bodies should be installed by then.
- mytimac
- Business Member
Just in stock.
Parts for Associated Models
9143 B3 Front Shock Strut Carbon
9142 B3 Front Shock Strut Fiberglass
TK1200 Trinity Blue Alum Motor Mount RC10GT (old chassis)
CLN5228 Calandra Blue RC10GT Front SHock Tower
Parts for Losi Models
A1009 Threaded Rod 1.5
A3266 Slipper Hub Plate Flange
A9712 GRaph Fr Arms VLA XXXT AD2
Parts for HPI Models
4310 HG Precision Body Mounts Rear for most RS4 models
- mytimac
- Business Member
All this just came in, but wait there is more not listed here. (mostly Losi)
Check the video. https://www.youtube.com/watch?v=U55XcJP_HLI
Also the new bodies video. https://www.youtube.com/watch?v=J6iMMoXAj1k
Spend $60 and Save $5. Use code 60Bucks at checkout.
J220 Jammin Wing for RC10 and others
a1010 Front Shock Tower
a1107 Front Shock Tower
a2005 Adj Threaded Rods w/ends 1.125"
A2007 Hinge Pin 1.42"
A3021 Ball Bearing Diff Gear Only
A3056 Retrofit Transmission Slipper Shaft Spacer Pin & Clip
a3074 Tranny Diff Gear 2.19
a3075 Trans Upper Gear and Idler
a3121 Hydra Drive Friction Slipper Back Plate
a3233 Front Dogbone Driveshaft Sedan
a3244 Access Plugs Black
A4052 Foam Insert for Chassis
A9941 Bearing Spacer/Wheel Washer Set
A5004 Shock Shaft .6"
a5020 X-Long Rear Shocks 1.2 Grey
a8019 GTX-S Body for GTX and NXT
- mytimac
- Business Member
A few Losi parts in.
A2100 XXXCR Rear Tower
A2942 Blue Motor Plate and Front Brace XXX XXXT
A6406 1/16 Pin Assortment
A1122 Fr Spindles and Carriers XXX
A5036 .9 Black Alum Shock Body
A5152 2.5 Shock Spring Red
- mytimac
- Business Member
Losi parts in. A1001 just sold as I was making the list. Someone clearly had email notifications turned on.
A1001 Front Arms
A1002 Front Carriers Spindles
A1117 Fr Arms VLA XXXT
A1004 Front Shock Tower
A2123 Rear Hub VLA XXXT
A2139 Rear Arms VLA XXXT
A2927 Composite Gear Brake Hub
A3039 Diff Rings XXXCR
A3123 Slipper Friction Pad
A4005 Front Mini Bumper
A4129 Pivot Block Front XXX
A4131 XXX XXXT Bumper
A5023 Shock End Cups Clamps
A8102 Wing Buttons
A8106 XX Wing Wire
A1001 Front Arms
A8102 Wing Buttons
A8106 XX Wing Wire
- mytimac
- Business Member
Team Associated
7255 Servo Saver Plastic
6800 Rear Rims Black
6850 Front Rims Black
Last Fall we did a run of dyed RC10 Rims when we had more bulkheads dyed. We did some more again this Fall. Only 5 black sets available. 9 sets of Fluorescent Yellow coming back in stock soon.
http://sabulatech.com/storefront/index.php?id_product=4603&controller=product
Sabula Tech
A1101 XX XXT black and blue bulkheads back in stock. We also have a new limited color, orange.
A6206b Blue 4-40 x 3/8 Alum SH Screw
A6217b Blue 4-40 x 5/16” Aluminum SH Screw
A6220b Blue 4-40 x 1/2 Alum FH Screw
A6221b Blue 4-40 x 5/8 Alum Cap Screws
A6305b Blue 4-40 Alum Lock Nut Low Profile
A6306b Blue 4-40 Aluminum Mini Nut
A6305p Purple 4-40 Alum Lock Nut Low Profile
A6306p Purple 4-40 Aluminum Mini Nut
A6305bk Black 4-40 Alum Lock Nut Low Profile
A6306bk Black 4-40 Aluminum Mini Nut
Trinity
tk3050 Kinwald Blue Alum Screws 4-40 X 1/4
Team Losi
a3930 84 Tooth Spur
a9930 Alum Upper Gear and Shaft 2.19:1
A9714 Graphite Kickplate Bulkhead XXXNT
Sabula Tech
Trinity
Team Losi
a3930 84 Tooth Spur
- 1358 Views
Last post by mytimac
- 897 Views
Last post by amx73
- 1232 Views
Last post by MONSTER
- 55 Replies
- 5308 Views
- 577 Views
Last post by RCveteran
- 2251 Views
Last post by jimbobarooney
- 26 Replies
- 3825 Views
Last post by Jared J
- 1456 Views
