Inventory updates
Moderator: mytimac
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 54 times
Inventory updates
I will be posting here when there are what I deem important inventory updates. You can usually check the New Products section. http://sabulatech.com/storefront/new-products.php But that only covers things that are new to the store and have never had inventory available. So this section will also cover stuff that has come back into stock. Still, the best way to know if something is back in stock is to add your email address for notification on that products page.
- mytimac
- Business Member
Re: Inventory updates
Kind of a late update for the first post here. Two weeks ago there was a huge update. The store categories got rearranged a little bit to accommodate all the new items. Over 90 new product numbers got added.
Parts for vintage Kyosho, Tamiya, Yokomo, Futaba, Associated, Superior Racing, MRC, TRC, HPI and more.
Lots of RC10L and RC12L added and more to come soon.
- mytimac
- Business Member
New and Returning products for 10/31
Pictures for the new stuff will be added in the next few days as time allows.
Back in inventory products
RPM, rpm7030, RC10T Rear Arms in White
RPM, rpm8125, Losi Street Weapon Hex Adaptors to use all hex drive sedan wheels
Team Losi, losa4219, Front and Rear Bumper Set XXX4
Team Losi, losa4238, Upper Bumper Body Mount Brace XXXS
New Products
Trinity, TMF1112, Red Anodized Alum Servo Mounts for XXXS
Team Associated, asc6606, Bearing Adapters RC10 RC10T RC10DS
Team Associated, asc8315, RC10L SS Nerf Bars Graphite
Team Associated, asc8307, RC10L SS Front End Brace Graphite
Team Associated, asc8303, RC10L SS Front Bumper
Team Losi, losa9500, Complete Mechanical Speed Control
Team Losi, losa9960, NXT GTX Graphite Center Chassis Brace
Trinity, s6087, 87T 48P Super Spur Zero Friction Spur Gear. Only for single disk slipper setups.
Traxxas, tra1986, Dust Cover. For Blue Eagle - Eagle - Hawk 2 - LSII
Traxxas, tra1987, Dust Cover and Access Plug. For Blue Eagle - Eagle - Hawk 2 - LSII
Traxxas, tra1943, Bellcranks Steering Radius Arm (plastic only) TRX-1 and Blue Eagle
Thorp, DB4506, Gear for use with Dirt Burner Tamiya Diff kits 4500 4540 4550 4580 4581
Thorp, DB4507, RH Pressure Disc for use with Dirt Burner Tamiya Diff kits 4500 4540 4550
MIP, mipCVD1, CVD axle for RC10
MIP, mipBB10, Battery Brace for RC10 and RC10T
MIP, mipMB2, Losi Bone Outdrive for use on LRM transmission- not for XX transmission
Kyosho, KYbb43, Wheel Hub USA1 Big Boss
New Products
- mytimac
- Business Member
Oh geez just about forgot the Tamiya parts
Tamiya, tm9005213, D Parts Windshield Blackfoot
Tamiya, tm0005356, D Parts for Astute and Super Astute
- mytimac
- Business Member
Just put some stuff back into inventory. Have some new product additions that will go up on Monday probably, mostly Losi.
RC Performance Specialties, 915, RC10B2 Titanium Turnbuckle and Hinge Pin Set
RC Performance Specialties, 711, RC10DS Nitro DS Titanium Turnbuckle Kit
Losi, A3919, 75T 32P Spur for GTX NXT
Losi, A3918, 74T 32P Spur for GTX NXT
Losi, A3202, XX4 HP Rear Drive Belt XX4
Losi, A3014, Universal Pivots
Losi, A3074, Tranny Diff Gear 46T
Losi, A9365, Clutch Shoe Springs GTX
Losi, A3982, 82 Tooth Profiled Spur Jrx2, JrxPro, JrxT, Junior
Losi, A4217, Fr Rr Bumper Set XX4
Losi, A3244, Access Plugs XX4
Losi, A4222, Wing Mount Set XX4
Losi, A3045, Slipper GEar Cover Plug
Losi, A1007, Bulkhead Hinge Pins
Losi, A2017, Rear Pivot Support Jrx models
Losi, A6013, Rod Ends Bright Blue
Losi, A1018, Adjustable Link Set LXT, GTX, NXT 1st gen XXX
Losi, A7039, XX Front Wheel Discs
Losi, A1214, XXXS Front Arms
- mytimac
- Business Member
New additions today, pictures are already up.
Custom Works, 6214, Street-Trac Tires
Associated, 8177, RC10L Front Bumper (sold already)
Team Losi, a3213, Main Drive Belt XXX4
Team Losi, a4231, Foam Bumper Street Weapon
Team Losi, a9388, 19T Clutch Bell 75T Spur NXT GTX
Team Losi, Body Mount Set, XXXS
Back in Stock
Team Losi, a7061 One Piece Front Tuck Rims Jrxt Junior T
Traxxas, 1943, Bellcranks Steering Radius Arm TRX1 and others
Back in Stock
- mytimac
- Business Member
Added back into inventory listed first.
Team Losi
A3076 2.61 Diff Gear
A3097 molded outdrives with metal rings
A3098 molded diff thrust bearing
A2013 Rear Toe-in Link (5 link)
A3112 Hydra Drive Dual Slipper Conversion
A3984 48P 84 Tooth Profiled Spur
A4005 Front Mini Bumper Kit
A8105 XX Wing
A8107 Wide V Wing
A1233 Spindle Carriers Bushings
A1224 Fr Spindles and Carriers
A9752 2 Deg Graph Spindle Set XXXS
A1003 Front Bulkhead
A9807 1 Deg Rear Hub Set
A1109 Fr Shock Tower XXXT XXXNT
A2925 Monster Diff Gear
A3027 Univ Bearing Cross Rebuildable
A4124 Front Spindles Carriers Rear Hubs XXX
A4160 Kickplate Bulkhead Brace XXXNT
New Items
Team Losi New Items
A3301 Drive Belt 330mm White JRXS
A3302 Drive Belt 390mm Gray JRXS
A6015 Super Duty Natural Ball Cups
A7301 Rear 4-row spike tires (jrx2 era)
A7367G IFMAR Pin Rear
Trinity New Items
tk2800 XX Battery Strap
6013 Pro Wing Buttons Purple
tk3043 Kinwald Pro Shock Bushings (Losi)
Lunsford New
OR-250 On-Road Associated Style RC10L and like (Titanium Front Axle Kit)
ProLine New Items
2567 Cone Dish 2.0" Rear Rims for RC10L Allows to fit rubber semi pneumatic tires
Team Losi
A8105 XX Wing
A8107 Wide V Wing
New Items
Team Losi New Items
Trinity New Items
Lunsford New
ProLine New Items
- mytimac
- Business Member
More parts added, all for Losi models.
new items
MIP, 1302 Alum CVD Kit for XX XX4 Buggy Rear
Associated, 1335 XXT Titanium Turnbuckle Set Blue
Trinity, 2082 Brush Hood Alignment Tool
back in stock items
Also just put a bunch of used Losi stuff on eBay.
http://www.ebay.com/sch/oldrccom/m.html?_nkw=&_armrs=1&_ipg=&_from=
new items
back in stock items
- mytimac
- Business Member
Hit up a bunch of old hobby stores during recent trips, so I have some stuff back in stock. I will also have bunch of new product additions later this week. The new additions are old Associated, Losi and Traxxas items.
Parts for Associated.
8177 Front Bumper RC10L (black)
8891 Dual Sport Rear Wheels Black (looks like this just sold this morning)
6711 Resistor for throttle
6577 RH Diff Outdrive for 2.25:1 Diff
9165 B2 B3 T3 Steering Bellcrank
7371 T2 Rear Motor Guard Black
A6003 Foam things
A4229 f/r Body Mount Set XXXS
A3074 Transmission Diff Gear XX and XXX
7379 RPM One Piece Center Link for XX
A4236 Fr Rr Bumper Set XXXS
A3945 88T Spur Gear XXXS
A4141 XX and XXT Front Sway Bar
A6003 Foam things
- mytimac
- Business Member
The new stuff has been added.
Parts for Traxxas
4621 Traxxas Differential Shaft Adjusting Nut (LSII Blue Eagle)
4720 Traxxas Outside 48pitch Gear Set (bullet radiator)
1824 Traxxas Upper Oil Damper Bracket Rear (sledgehammer)
1681 Traxxas Gear Box Halves (sledgehammer)
1781 TRaxxas Gear Main Differential (bullet radicator)
1950 Traxxas 1950 Suspension Arms Long Rear (Bullet Eagle Rad 2 and Hawk 2)
1161 MIP Shiny CVD Bones RC-10 B2 B3
9157 Team Associated Servo Saver Spring Nut replaces 7257
8211 Team Associated RH Rear Wheel Diff Spacer RC10L
9232 Team Associated B2 B3 Battery Hold Down Short Carbon Fiber
9231 Team Associated B2 B3 Battery Hold Down Short Composite
7321 Team Associated T3 Front Battery Body Mount Composite
9131 Team Associated Front Top Plate Carbon Comp T3 B3 B2
Parts for Losi
1052 MIP Losi Rear Shock Shaft 1.2
tk3002 Trinity Team Kinwald XX Front Brace
tk5008 Trinity Battery Strap Losi XXX Buggy
a9749 Team Losi Graph Fr Pivot Support XXX4
a3954 Team Losi 128T 64P Spur Drive Pulley XXXS
a9320 Team Losi Aluminum Exhaust Flange Manifold GTX
a4023 Team Losi Graphite Center Chassis Brace GTX NXT
Parts for Traxxas
Parts for Losi
- mytimac
- Business Member
Updated inventory, back in stock.
Associated
6214 Front Block Carrier 20 Degree White
6217 Inline Steering Block Black
6390 Rear Wheel Knock Offs
Losi
A1003 Front Bulkhead (Sorry in advance for price increase)
A1102 Front Bulkhead Brace XX XXT
A1108 Front Shock Tower XXT
A3076 Diff Gear 2.61:1
A3081 Buggy Dog Bone and yokes
Associated
Losi
- mytimac
- Business Member
Got some great new things and some returning items.
Associated parts
7326 T2 Battery Brace
8177 RC10L Front Bumper
9266 B2 Rear Suspension Mounts 2 Deg
8184 Antena Shock Mount RC10L (white)
9652 78T 48P Spur Gear
7372 T2 Gear Dust Cover
HPI parts
a373 Body Mount Set Nitro Rally
a360 Axle joint hub set (pro2?)
Losi Parts
a6053 Molded Susp Pivot Ball XXX4
a6054 Steel Pivot Ball Set JRXS
a8100 Standard Wing (all pre-xx buggies)
a6003 Foam Things
A7044 Front 5 Spoke XX4 Wheels White
a4056 XXT Front Body Mount
a9813 XX Rear Shock Tower
a7030 XX Front Disc Wheels White
a6200 4-40 x 1/8 Shoulder screw (screw for rigid steering arms)
Associated parts
HPI parts
Losi Parts
a6003 Foam Things
- mytimac
- Business Member
Got a bunch of stuff back in stock and some new things for Losi models. One lone part for Associated. The new stuff will have pictures later this week.
8211 RH Rear Wheel Diff Spacer RC10L
Parts for Losi
1335 Titanium Turnbuckle Set Losi XXT Blue Anodized
TK3078 Kinwald XXCR Shock Tower (blue flake)
a9961 Graphite Transmission Case Set GTX NXT
a3054 Retrofit Case (already sold)
a2140 XXT Rear Suspension Arms
a8108 Maxi-Wing XX4
a8106 Wing Wire jrx (already sold)
a4103 XX Main Chassis with Brace (X-Long)
a9909 X-Long Graphite Battery Strap for XXT
a2014 H-Arm Rear Conversion Kit
a9709 XXT Graphite Front Arms
a2112 Rear Pivot Block 0 Deg
a9830 Graphite Composite Rear Pivot Plate XX
a1016 LXT GTX NXT Front Arms
a4216 Motor Mount Clamp
a1131 Front Stub Axles XX
a8101 Wing Wire (already sold)
a9809 Graphite Rear Arms XXT
a1136 Front Axles XXT
a3055 Retrofit Case (already sold)
a3001 Jrx transmission Case (already sold)
Parts for Losi
a8108 Maxi-Wing XX4
- mytimac
- Business Member
Ok a8106 from my previous post today is back in stock because it turns out the a8101 was not in fact an a8101. I went to ship it and realized sitting next 2 each other that they looked the same. The Jrx a8101 should be wider. The buyer didn't want 2 a8106 wires. So the a8101, that really is an a8106, is back in stock.
- mytimac
- Business Member
New parts and some back in stock
Traxxas
2818 Rotary Mechanical Speed Control
HPI
4480 X Pattern Radial Tire
4400 Pro Belted Slick Tire
3854 VIntage Stock Car Wheel
Ride
RS64 J38 Belted Slick Tires
Losi
a4047 Molded Chassis Brace
b1001 Mini-T Painted Body Silver
a8330 Street Weapon Stickers
a7041 5 spoke front wheels (see note)
a7701B lst S-01 Slick Tire (blue)
a3120 Slipper Shaft With Hardware
Tamiya
9495197 Sticker Set for Nissan 300zx
RPM
7385 Heavy Duty Front Carrier JRX buggy and JRXT
Traxxas
HPI
Ride
Losi
Tamiya
RPM
- 1358 Views
Last post by mytimac
- 897 Views
Last post by amx73
- 1232 Views
Last post by MONSTER
- 55 Replies
- 5308 Views
- 577 Views
Last post by RCveteran
- 2251 Views
Last post by jimbobarooney
- 26 Replies
- 3825 Views
Last post by Jared J
- 1456 Views
