artfull dodger wrote:I vote for a Futaba servo of some kind. Mike
Great story of reliability! I must admit back int he day Futaba was the automatic choice here in the UK. Most hobby shops said they were about as good as it gets. Obviously I know things move on and new brands appear. But I think for the sake of old times I will try and get a Futaba servo. I wish to use my BASIC old Sanwa Dash R2 transmitter (no end point adjustments or any other tricks!) with my old Futaba mini 27Mhz receiver. Specific Futaba servo recommendations are welcome. I am happy to pay more for something decent!
Stumpy wrote:Unless you are using a radio that has "end point adjustments", FORGET about using digital servos.
I am now using a Futaba S9551 and S9452 servos.
Just keep in mind that unless your ESC has a 6Volt/3Amp BEC, you are not going to get the most from any servo... If you have an ESC with a 5V/1A BEC, then fitting an external 6 Volt, 5A - 10Amp BEC may be a smart option if you plan to get the maximum performance from a (digital) servo.
So.... I just did a search and the Futaba S9551 and S9452 servos are digital. So are they not suitable with my radio and receiver? If not what analogue Futaba are as good or close?
I just picked up this one for my new 2wd buggy, let you know after I hit the track, it may end up in my crawler and put the servo above in my buggy, depending upon my "feeling" with this one.
Those units both have nice specs, right in the ranges I'm looking for, and the price is right, too. Let me know how that second one works out. Thanks!
- "unknown" brand
- not lo-pro...
controlling a $90 top-of-the-line servo with an entry-level radio from 20 years ago isn't the most reasonable thing to do... it's like dropping in a hot mod motor in a car that isn't ballraced...
Paul
So it seems I may need a new radio after all. Which means I may as well look at 2.4...
not necessarily 2.4 (although it would be weird not to go this route) but something both fast enough and adjustable to leverage a top-line servo's response.
I can sense a new thread coming And I will not advise this time anymore to not offend anyone...
Paul
Lonestar wrote:
any modern mid-to-high range "low profile" servo will deliver the performance you are after. Try for instance a savox 1251, it's about 7kg.cm, 0.1s-ish/60deg, metal geared, digital, and $50. Sanwa and futaba have comparable products, a bit more expensive though but still affordable.
Paul
+1 for the Savox 1251, I tried one on a whim and haven't looked back. Now I have them in almost all my runners.
askbob wrote:Just out of curiosity, are there any of the older(mintage ) higher end servos that will compare speed wise with say a new Futaba 9551 or similar?
Interesting thought! Ideas welcome...
If I go 2.4....
I want a stick radio. Futaba are stupidly expensive now. How is it a 6 or 8 channel radio is way cheaper than a 2 channel car radio. 'Kin rip off or what!!!
So that leaves Sanwa Gemini as the only choice. Job done:
yes, 9551 is 0.14s/60deg @ 6V, any $100 (from bitd) competition servo from the late 80's would do that.
Now, it pumps out 10kg.cm at the same time... which means it can go fast under significant load.
you could only see this kind of performance in the mid 90's I would say, probably the later KO 1000 series and some of the 2000's. Later, the first Sanwa ERG's played in that ballpark. I am not knowledgeable enough about futaba, which is a quality brand, granted, but that I always found overpriced vs. KO and sanwa.
what's impressive is that the 9551 does it in a lo-pro frame... which means smaller motor than usual.
Paul
Anything around .10 - .13 and around 150 oz/in. is a pretty good servo, not too fast, not too slow and reasonable torque for most cars (monster trucks aside).
Most servos that are high speed lack slightly in the torque department and high torque servos tend to lack speed, it's a trade off (unless you go with HV servos but they cost). The specs I posted above is a good all round rating.
Digital servos tend to have a higher resolution, smoother and better holding power. Analog is a bit slower and less precise but is fine for a budget servo.
Definately stick to a quality name brand servo, stay away from the cheap-n-nasty servos though.
They are both "local" brands since the Hobby People stores are here in SoCal. No doubt both of them are straight from china with a different sticker on them. Neither are low-profile, both are full size, but smaller than my Airtronics 94258, even if just by a smidge.
I picked up an Align servo the other day for a steal, put it in my gold pan...um, its TOO fast for my old reflexes. Poor car never hit more pipes in its life
Align = orion = savox
Lonestar wrote:yes, 9551 is 0.14s/60deg @ 6V, any $100 (from bitd) competition servo from the late 80's would do that.
Paul
Paul, now you're advising, which is always helpful & appreciated. Before you were saying "research this yourselves".
I think the question was still not right to be asked, but hey, let's move on... still trying to help as you can see
I have been using the blue case Bluebird servos for a few years with a lot of success. I will check the model number when I get home from work tonight.
I'm building a rc10 DS in one of the new 6001 gold pans.
I was considering replacing the GT style bell cranks with b2 style so I could free up some space to move the electronics forward.
Is this a bad idea?
Are there any ways to do this without...
:( Argggg I want to click the pics for clarity but it won’t work…. Why does this happen sometimes !?!
Last post I made with a couple pics the last one did this. I know I placed them all inline in the single post
I've been getting Futabab S3305's for my recent builds because I recognize the name from when I raced in the early 90's so I presume they're a quality item (rightly or not). I have HiTec 635MG's in my...
If going with Savox, apparently there's a big difference between SC-1257 and SH-1257 servos.
Hey all. First post for an RC newbie here, so be prepared for goofy questions! This Jerobee Commando McLaren has been in my family since the '70s. I want to get it going again and keep it. There was only one crystal stamped NKD 26.640mhz, so I...
Ok thanks I would do that as a last resort. Thanks.
please bare with me, I'm new to 1/4 scale never ran dual servos for steering, I have a three channel radio and reciever, I am not sure how to use the aux input for the second servo. Could I use a y cable into one slot on the receiver?
there are two futaba S3305 servos on the front end for steering and a duratrax sx100 servo for the throttle and brake. Would these servos work with a JR R135 receiver and JR XR3i transmitter? I am a spring chicken with RC electronics forgive my...
I've been building three extra runners to try to get my rc buddies hooked on the rc10s. I'm having some trouble with the steering rack on one car. I have the houge bellcranks but I'm missing the small threaded adapters that go into the bearing can I...
I have used the Traxxas #2543 bell cranks for a few builds so far and I like them a lot. I bought a couple thin walled 3/16 od tubes and cut it to length. You can use left over bushings or bearings.
I used them on the black and blue car I built a...
I have a B-stamp project that is getting closer to a ready-to-build pile of parts, and the theme will include white AE mostly nip bits. I would rather not do the OEM steering, but want to preserve the white theme. The Houge steering and Worlds...
Hi, I just recently picked up a bunch of Futaba and Kraft recievers and servos and was wondering if anyone had any info or knew what dates some of these were made. Looking to install them in some upcoming restorations. Cheers
The Futaba receiver & esc are listed on the Futaba site here:
