Thanks. Ryan.
Cool, well I might just have to oil these babies up and take her to the track, the buggie runs, even has an old Futaba two stick controller with servos installed , just plugged in a battery and off she went! The roll cage doesnt really fasten to anything in the rear, I know the front snaps over those 2 nipples(yeah baby), but what holds the rear of the roll cage down from flapping in the breeze? I think Im missing some important pieces in that respect.highwayracer wrote:Actually, the beagle shocks are pertty good when set up correctly (oil level). The collars are made of the same plastic as the arms...so they are much stronger. There's a plastic bushing inset in the bottom peice (that screws on to the shock body) which means it never touches the shock shaft. In addition, you don't have to use a special tool to remove it.
Regards,
highwayracer
MrRadar and 5 guests
