Yokomo 870c, works 91/92/93 diff ball size
fakiee
Post by fakiee »
slazzaro
Has thanked: 6 times
Been thanked: 6 times
Re: Yokomo 870c, works 91/92/93 diff ball size
Post by slazzaro »
Diff balls are 3mm, thrust balls 1.5mm (but also 5/64" fit, just use one ball less).
Bye :wink:
Kyosho Turbo Optima, Optima MID Custom Special, Optima MID Custom Special truck converted
Yokomo YR4 PRO, YZ-870C
Associated TC4, B3 (x2), B4.1 worlds, C4.2, B42, B44, B6.2, B6.2d, B64
Losi XXXT MF2
Tamiya M05
..more in the past, more in the future..
fakiee
Post by fakiee »
Cheers Slazzaro,
Would 3mm Chrome Steel Balls do the trick or should I be looking for something harder?
slazzaro
Post by slazzaro »
I think chrome steel are just fine, they will last a bit less but the first part to replace will be the rings anyway.
Bye :wink:
Losi XXXT MF2
Tamiya M05
Return to “Yokomo Forum”
