RC10 worlds rear RPM chassis cut template
lowrydesign
Has thanked: 11 times
Been thanked: 22 times
Post by lowrydesign »
so i have a set of WORLDS CAR RPM SUSPENSION MOUNTS but i need a copy of the chassis template so i can cut my chassis.
if any one has one could you scan/photocopy it and post it?
thanks
kenooze
Re: RC10 worlds rear RPM chassis cut template
Post by kenooze »
I'm able to send you one if you want !
just pay shipping charge .
lowrydesign
shipping to here and back?
even a digital picture from directly above would work.....
lowrydesign wrote:even a digital picture from directly above would work.....
it's not just a cut template, but a drill template. two new front arm mount holes need to be drilled and countersunk, so it needs to be accurate.
do you have the worlds arms to use with the mounts?
kenooze
Post by kenooze »
Only one way shipping !
I have 2 and build my car, So I need anymore the other !
lowrydesign
scr8p wrote:do you have the worlds arms to use with the mounts?
yes i have the front and rear arms and the front shock tower, found them at my parent house over the holidays!!!
Users browsing this forum: No User AvatarBing [Bot], No User AvatarDotNetDotCom.org [Bot] and 8 guests
