How do you guys have your slash setup?
the stock setup is crap and ive been messing with different setups and i cant seems to find a good setup. Can anyone help?
- bearrickster
Re: How do you guys have your slash setup?
Mine is right out of the box, other than shock spacers to tighen it up to keep it from body rolling over on the Tires.
- bearrickster
We beat mine to death and its hart to roll? if it does it goes back on its wheels
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Jesse, what conditions are you running in? On a track, in your yard?
I have bashed/raced box stock and modified, and to be honest, there is not much difference (on the track).
For the record (if it helps):
Front:
Traxxas Big Bore Shocks, stock piston, stock spring, 50 wt Associated oil, no clips. Outside on arm.
Rear:
Traxxas Big Bore Shocks, stock piston, stock spring, 40 wt Associated oil, stock clip. Stock postions (as out of the box)
Battery to the rear (lipo), no weight added. Rear body mount in highest position (stops the tires from rubbing the body when landing big jumps). -2 camber all around.
Novak Cyclone Speedo, B&R motor (19T single, 550 can), stock gearing (18/86).
Great accelleration, just a touch more top end than the stock Titan motor. On a 80 foot straight, I can pull a foot or 2 ahead of a stock truck.
Front:
Rear:
Iam gonna bash it and race it on carpet but for the bashing is the setup i need to know about. i wanna keep it stock just dont wanna roll it every 6 seconds
- JK Racing
Move all your shock bottoms out one hole, go to thicker oil in all the shocks. Start there.
Just as i got my slash set up for me i broke the front shock tower and both shock caps
Go ahead and either replace the shocks or at minimum install the aluminum shock caps.
- 877 Views
Last post by vwjuice
- 1032 Views
Last post by purpletimbo
- 1449 Views
Last post by andymac0035
- 26 Replies
- 2612 Views
Last post by bearrickster
- 34 Replies
- 3588 Views
Last post by carloco8
- 599 Views
Last post by soniccj5
- 523 Views
Last post by mugen69
- 701 Views
