Question about Hyperdrive and RC10 Trans
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Which trans can you use the Hyperdrive on? I'm looking at the spur or the bottom diff pulley as they call it and looks like the 6 gear is the only one it will work on.
This is all very interesting!
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
Re: Question about Hyperdrive and RC10 Trans
I'm pretty sure that setup predated the stealth. Pancars and sixgears.
- Has thanked: 36 times
- Been thanked: 1318 times
i don't have one, but i'd have to guess that at long as the holes in the spur for the diff balls line up with the screw holes on the stealths outer slipper hub, you should be able to use it on there too. or an mip trans.
- a01butal
That's just it they don't line up with the stealth screw hole and it is a very tight fit over the outer slipper hub. I dont think it will even work with a MIP trans.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Can you post a picture? If it fits over the hub maybe you could drill an extra hole in the hub and tap that (or drill an extra hole in the pulley)
- 25 Replies
- 3799 Views
Last post by mrlexan
- 1460 Views
Last post by littleVETTE
- 2185 Views
Last post by discgolfer72
- 539 Views
Last post by bennettj325
- 2057 Views
Last post by Carknowledge101
- 761 Views
Last post by Johnboy72
- 1619 Views
Last post by blubblood
- 24 Replies
- 4943 Views
Last post by JosephS
