Charger Fuses?
MONSTER
Charger Fuses?
Post by MONSTER »
I have several old Tower Hobbies Timed Chargers. The fuses have blown in all of them. They call for a .75 amp fuse, but I could only find .50, and 1.0 amps fuses when I went to Town. Which should I use, or should I just wait until I get what they are supposed to have?
Stumpy
Re: Charger Fuses?
Post by Stumpy »
Do yourself a favour and throw them in the bin (or back in the box in the shed where you found them) and go and buy yourself a peak detection charger.. :) :) :)
You will charge your batteries faster, get longer run times, and you battery packs will last longer (before needing to be replaced), especially if you are using NiMh battery packs.. :D :D :D
Cheers
civilguy
Has thanked: 5 times
Been thanked: 14 times
Re: Charger Fuses?
Post by civilguy »
Monster- I've used both higher & lower rated fuses in a pinch before. Trying a lower rated one almost always guarantees more blown fuses as they can't handle the load. While using a higher one I always monitored the temp of the charger and the battery-- and only did that when I had to for racing.
I would try the .50 fuse first and see if you can get through a charge. Then find the correct size when you can-- Radio Shack is typically where I find my fuses. Good luck!
FYI your stuff is going out today-- yesterday after work the line at the PO was out the door, so I passed. :wink:
Jeff
MONSTER
Re: Charger Fuses?
Post by MONSTER »
We should both have our stuff by Monday then. Thanks.
On the fuses, Radio Shack is where I found these. They looked at me like I ask for plutonium, when I ask about the .5 fuses. Have I mentioned before (I KNOW I have, lol) that I live the STICKS....of Mississippi, no less, LOL. They are NOT my Main Chargers. They are for the Rent-A-Track thing I want to do.
