check my gear
- GJW
check my gear
fellas im wondering when this gear was released for the lrm losi transmission is it an original or a aftermarket item
- FasterLouder
- Has thanked: 13 times
- Been thanked: 59 times
- Been thanked: 12 times
Re: check my gear
That is a losi part, A-3024 low friction gears. I'm not sure what is low friction about them exactly, but they may be a different material than the standard gears.
In the pic below the bottom loose gear is fresh out of the package. the upper one is a standard output gear. The low friction gears are darker in color. I do not have a standard set of gears to compare all of them side by side, so other than the differences in the output gears I'm not sure if the other pieces have differences.
Re: check my gear
These seem similar to the low friction white telescoping half shafts. Not sure, but assuming for the moment they are plastic, probably molded with a Delrin based or derived material. Delrin tends to have low friction properties to begin with. Some grades have PTFE added, generally known as Teflon. For a gear it would have to be a stiffer version of Delrin, the basic material is fairly pliable. I’m almost positive that the white sliders are made from a Delrin based material.
This is a fairly common material in the RC industry, the X Factory guys have mentioned it when discussing prototypes for example. Also used in 1 scale cars, sealed non greased ball joints, tie rods and such typically have inserts made with this stuff. I’ve used it in such applications.
Probably one of the first experiences with Delrin for many of us are the same, it was used for a few years for the wheels on Hot Wheels cars.
- mrlexan
Re: check my gear
Don't forget that Thorp/Dirt Burners released the same gears. It could be Thorp.
www.gojammedia.com
www.gojammedia.com
- mrlexan
Re: check my gear
I have seen black.
www.gojammedia.com
www.gojammedia.com
- GJW
Re: check my gear
alright thanks for the input there blokes, time to tidy the hobby room its a mess..cheers
Re: check my gear
don't say that. I thought I was done accumulating thorp stuff. . .mrlexan wrote:I have seen black.
- 750 Views
Last post by mikedealer
- 1160 Views
Last post by Tadracket
- 631 Views
Last post by purpletimbo
- 748 Views
Last post by mat69
- 25 Replies
- 2868 Views
Last post by RichieRich
- 632 Views
Last post by mikea96
- 23 Replies
- 2922 Views
Last post by superfly
- 2620 Views
Last post by justinspeed79
