http://s157.photobucket.com/albums/t59/THEYTOOKMYTHUMB/?action=view¤t=BrushlessRC10GT001.jpg
TC5 motor mount. I have tons of 48p stuff so I may try that down the road. I've cleaned up the wiring since then, but the battery still bugs me. When the bodies on you can't tell anyway, but I know what's lurking under there and it haunts my darkest nightmares....markt311 wrote:you could probably run a regular 48 pitch spur in 87 or 84 tooth if you wanted too since the gear ratio is the same as a T2. It would let you move the motor back a little to help with the battery placement. But I can also see wanting to run your nice Robinson steel spur gear too! Gearing it higher would help with the wheelie action but it looks pretty nice the way it is. What did you use to mount the motor?
Users browsing this forum: Bing [Bot] and 3 guests
