Stock Jrx-2 buildup
aconsola
Stock Jrx-2 buildup
Post by aconsola »
This is my most recent rebuild. it has all of the early version parts that I posted in my obsessive variations thread.
Note that there is not a single aftermarket part on it unless you count the robinson pinion. It has a losi stock motor (label colors are reversed from the boxart but it's all I've got) with a 24t pinion and 82 spur as per the original manual. I have not decided on a speed controller for it yet. I have a vintage painted body in decent shape, but I think I will use one of the forthcoming repros and paint it up like the one I had BITD.
I ate a lot of cookies I shouldn't have while building this one, it took all the willpower I had to build one up stock. :mrgreen:
I still need to find 2 more thin black spring clamps. I have a NIP pair but they are grey, I don't have enough of either color to make a matched set of 4
Re: Stock Jrx-2 buildup
looks great anthony. i'm sure i have some losi pinions floating around if you want one for it.
i have a 24t losi pinion if you want it. just let me know. :wink:
Doc J33P
Post by Doc J33P »
Lets see her with the vintage paint scheme. Beautiful by the way. Did you piece it together or buy a kit? I am at the beginning of building one up.
35 years of RC and still broke!
mrlexan
Post by mrlexan »
make sure you have the thick front shock tower..... that is something I missed that David pointed out to me. Luckily, I had one, just one.
www.gojammedia.com
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
mrlexan wrote:make sure you have the thick front shock tower..... that is something I missed that David pointed out to me. Luckily, I had one, just one.
yup and from the pics it doesn't look like you have it, soooo close to have a stock x2 Anthony :lol: j/k it's an awesome build and it surely misses a nice body and wing whether painted or not. You're also missing an old thin shock clamp it seems... Kudoz mate!
Come and visit the stable
aconsola
Post by aconsola »
It has the thick front shock tower, same thickness and material finish as the rear.
The clamps, I thought I had a matching set of black, but when i opened the package they were grey. I looked around my parts bins and found 1 thin grey clamp so I have have 3 grey and 2 black that are useable, and a whole bunch of broken broken black clamps. Eventually I'll straighten that out.
I would consider a boxart paint scheme, but that is way beyond my skill level. I'm more of a 2 color single piece of masking tape rattle-can type of painter.
mrlexan
Post by mrlexan »
Anthony, I will see if I have any of the skinny clamps left. I know there were thinning out, I might have one or two. Not sure which color.
www.gojammedia.com
Dr. Robotnik
Post by Dr. Robotnik »
Maybe dye a grey shock clamp black?
mrlexan
Post by mrlexan »
Dr, I don't thing Losi used the type of plastic that can be dyed... they certainly aren't made from any form of nylon.
www.gojammedia.com
mikedealer
Post by mikedealer »
not to hijack, but can these be used on a JRX2?
mikedealer wrote:not to hijack, but can these be used on a JRX2?
only with rear h-arms. they won't work with the 5 link.
Doc J33P
Post by Doc J33P »
Those things hubs or what? Look like they were made out of chalk.
Bongo Fury
Post by Bongo Fury »
That's looking pretty sweet buddy.
My suggestions, I believe the antenna tube should be an off white/natural color. A set of 1200SCR (or maybe just SC) batteries would be sweet, of course the 1400s aren't far off. The battery braid instead of bars is a nice touch.
What servo ya got? I like the Tekin receiver too, I’m not sure but I believe it fits.
Be careful with those orange rims, if they are early they crack real easy.
Enjoy!
aconsola
Post by aconsola »
The servo is a futaba S-148, with the old style logo plate.
Both front wheels are hairline cracked on the suspension side around the bearing holder. It is not visible from the outboard side, and I have no intentions of running this one so it will do. The old plastic must be rather fragile as both appear to be in great shape other than the cracks, I don't imagine they were run much, or at least not by someone with my driving skills :D
Return to “Losi Forum”
