Shock Oil and Spring Rate QUestions...
tecnica2001
Has thanked: 19 times
Been thanked: 29 times
Post by tecnica2001 »
1. Do you normally use heavier oil in the front shocks? usually between 5-10 wt difference between front and back?
If so,
2. Do you use the spring with the higher rate on the rear?? or also use the heavier rate in front along with the heavier oil??
3. What's a good starting point as to the position of the CVDs in relation to ride height?? should the CVDs be level with the tranny or should the tranny be a bit lower than the CVDs? if that makes any sense.
4. Same thing with the front, what would be a good starting point??
sorry for the newbie questions, I don't know too much about off road suspension set up, or suspension set up in general :oops:
Thank you. :D
edwin pibal
Re: Shock Oil and Spring Rate QUestions...
Post by edwin pibal »
download this book and have a read.
its the best thing i have ever read when it comes to suspention setups
http://www.teamxray.com/teamxray/showfile.php?file_id=4461
its aimed at 1/8 gas cars, but the explainations about everything are fantastic
Edwin
Hi, my name is Ed, and im a addict.
tecnica2001
:shock: Awesome, thanks a ton, that explains a lot. :wink:
Konich
Post by Konich »
What car are you running by chance?
tecnica2001
I'm running a Losi XX and an RC10T in the nationals, but I never really got the why's and what's when it came to suspension.
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
tecnica2001 wrote:I'm running a Losi XX and an RC10T in the nationals, but I never really got the why's and what's when it came to suspension.
The RC10T should be blue front #2 35wt, silver rear #1 30 wt. Basically a step up in stiffness from a GT or T2.
tecnica2001
I got red springs on the rear on my 10t, are those too stiff??
templeofspeed
tecnica2001 wrote:I got red springs on the rear on my 10t, are those too stiff??
Yes.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarElkcycles, No User AvatarNickB, User avatarXLR8 and 3 guests
