Need some help ID'ing some gears and a diff
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
Hi all,
I've got 3 things I need some help ID'ing.
First is a set of brass gears that look similar to a picture I've got of the MIP 4-10 transmission gears but I'd like to be sure. They are a metric pitch and have metric hardware...would they be for a Sand Scorcher by chance....?
Second is a Trinity diff pulley/gear with balls and a small bearing. This one's really strange, it's cut like a normal gear but it's got a rectangular valley down the center of it like a pulley for a belt...never seen anything like it.
Third is an MIP/Thorp differential (if memory serves) but I have no idea what vehicle it's for. The gear is 48 pitch and is much larger than a 2.25:1 Stealth diff as you can see from the picture. The outdrives fit a 5mm ID bearing.
Any and all help is greatly appreciated! Thanks!
Adam
Trinity Differential Pulley_Gear with Diff balls.jpg (102.85 KiB) Viewed 1519 times
Trinity Differential Pulley_Gear.jpg (76.57 KiB) Viewed 1519 times
MIP_Thorp Ball Diff.jpg (93.21 KiB) Viewed 1517 times
Has thanked: 1737 times
Been thanked: 1145 times
Re: Need some help ID'ing some gears and a diff
Matey,
The big white Trinity gear with the bearing seems to be a front diff gear for a Schumacher Cat/XLS/ProCat. Take a look here http://www.tamiyaclub.com/showroom_model.asp?cid=34127&sid=154, bottom picture.
I'm sure others will help with the other two lots...
adam lancia
Nice, thanks Alex!
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
I'm thinking the dif set with the white gear next to the associated dif is a traxxas proball dif. It should have flats on both sides of the output shafts and should either be a 45 or a 60 tooth dif gear. If you pull the 3 bolts off the output shaft showing there should be a stack of 7 items down under like a straight screwdriver head. Should be a thrust bearing with grooved washers on both sides then 4 bellville washers. Should be 12 diff balls inside. If you find these this is proball diff by traxxas...just a guess but just finished putting one together and looks alot like it. Are these heading to the b/s/t area?
adam lancia
Impressive! 60 tooth gear and flats on both sides 8) We gots ourselfs a professional here fellas ;) Thanks for the help klavy, and yes it is heading to the bst.
adam lancia
Anyone with an idea about the set of loose brass gears :?: Thanks!
klavy69
Moderator
Post by klavy69 »
Yeah, Actually now that I look at it the bottom brass gear on the left looks to be traxxas also. Compare outdrive flats with the traxxas dif of mine...er...yours. It should have flats on both sides again. Looks alot like the Traxxas #1783 gear brass outdrive(48 pitch). The others not so sure about...
Stumpy
Post by Stumpy »
In the pic with the screws in it..
The gear at the top left is the input shaft and gear from the Tamiys SRB series of cars..(i.e. Scorcher, Ranger, Rough Rider and SuperChamp.)
Cheers
adam lancia
Thanks guys, would these be stock gears or aftermarket? I know absolutely nothing about the really old school Tamiya's....Thanks!!!
Stumpy
Post by Stumpy »
It looks to be a stock Tamiya part..
adam lancia
Thanks, now I can list them properly. Much appreciated Stumpy!
klavy69
Moderator
Post by klavy69 »
Stock traxxas part also Adam.
Users browsing this forum: User avatarjuicedcoupe, User avatarXLR8 and 5 guests
