lipo cut-off module
- Has thanked: 36 times
- Been thanked: 1318 times
lipo cut-off module
so, is this a "must have", or a "wouldn't hurt to have" when using lipo packs?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPGM8&P=SM
- call-911
Re: lipo cut-off module
Thinking about how expensive Lipos are, I would think of it as a "must have".
Keith C
well, i'd guess it's worth the $25 if it saves you from corking a $140 lipo pack.
nevermind, this one already has it built in.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRHU7&P=SM
- Has thanked: 183 times
- Been thanked: 157 times
if i were in the market again i would go with a mamba max 5700 combo, it handles 3s and i think the green is neat lookin'call-911 wrote:Yep, I have a GTB. You may also want to look at the LRP Sphere.
- PBR Allstar
speaking of Mamba, I just picked up the Castle link today and I gotta say, it's pretty cool, I haven't gotten to test much with it yet, but the completely variable throttle and brake curve setup makes me feel all warm and fuzzy!
- Eau Rouge
- Been thanked: 5 times
I've raced LiPos for over a year now without cutoffs and have never needed one. I don't run any of my packs dry, stock or modified, or even come close, for that matter. My latest Novak GTB has an internal 6v LiPo cutoff in it now, though.
However, if you are running around in the yard/track, and generally drive your car/boat/helicopter until it dies, then you should definitely have a LiPo cutoff. It's one of those "how do you use it" kinda decisions.
Over discharging does not cause fires or other dangerous situations. Overdischarging ruins the chemicals inside a LiPo to the point where it won't take a complete charge again, and will never perform the way it was when it was new. The only way fires happen is when the pack is OVERcharged, or where there is a puncture that breaches the internal chemicals (cheap Chinese packs).
d
d
i think the only time i'd be worried about discharging the pack too low would be during practice. you know.................. you run the car for awhile, bring it back to the pits, change some things, go back on the track, bring it back in the pits, blah blah.
good to know, now i'm not nearly as afraid of them...Eau Rouge wrote:Over discharging does not cause fires or other dangerous situations. Overdischarging ruins the chemicals inside a LiPo to the point where it won't take a complete charge again, and will never perform the way it was when it was new. The only way fires happen is when the pack is OVERcharged, or where there is a puncture that breaches the internal chemicals (cheap Chinese packs).
d
- 748 Views
Last post by tamiyadan
- 1420 Views
Last post by Steve71
- 911 Views
Last post by mrlexan
- 1328 Views
Last post by fordtransman
- 620 Views
Last post by Goatless
- 957 Views
Last post by Hcp22
- 1142 Views
Last post by gtv1
- 654 Views
Last post by Hcp22
