What pinions are you all using?
vonmarshalll
Has thanked: 29 times
Post by vonmarshalll »
I have 2 different RC10’s nearing completion, one with a 10.5t Hobbywing Justock and the other with a 17.5t motor.
I had a 23 and a 25t 48dp pinion lying around but seem quite restricted in how the motor is orientated and guess I can only fit something like a 20 and maybe a 28.
I am using the FanRC Stealth but believe the dimensions are identical to AE.
Keen for any advice before I buy some more pinions that don’t fit!
Has thanked: 273 times
Been thanked: 2109 times
Re: What pinions are you all using?
With brushless, you might have to switch to a slightly smaller spur in order to get your desired gear ratio.
guggles
Has thanked: 26 times
Post by guggles »
32/81 is what im running with a 17.5 I believe.
Here is the gearing chart from the 2014 Worlds car.
vonmarshalll
Interesting link…
So 19,20,or 21 should fit in the small range and 28-30 in the larger.
I did not know I was restricted until I tried to fit one.
21 or 30 recommended for the 17.5 with a * by one.
I think I’ll experiment and get one of each.
Thanks
RC10th
Has thanked: 55 times
Been thanked: 1586 times
Post by RC10th »
21 is for dynamic timing
30 is for blinky
For 17.5 that is....
Has thanked: 365 times
Been thanked: 478 times
6.08 FDR? Man.... I'm at 5.61 FDR at 43* on a Trinity Slot 2 17.5 with a 30mm fan and with NC summer indoor racing (no AC at our track) I'm under 140F on the motor in a 6 minute heat. They're gearing conservatively. That B4 slipper plates setup takes a 72T spur easily and opens up gearing options
vonmarshalll
RC10th wrote: Fri Jun 27, 2025 7:30 pm 21 is for dynamic timing
30 is for blinky
I’m using a Justock esc / motor and if I race it will be in restricted classes so blinky it is.
Having said that there is talk of switching to 13.5 so I may get the 28 as well and see what difference, if any, I notice when it is on my 17.5 while practicing.
