Kyosho mint green paint
threejean
Post by threejean »
Good afternoon,
Has anyone come up with a paint color that matches the mint green parts on the Kyosho 20th anniv. Ultima? Or possibly one that compliments it? Having no luck so far. The manual calls for mixing bottled paint, but I'm looking for something I don't need an airbrush for.
Thanks!
Dangeruss
Has thanked: 425 times
Been thanked: 1408 times
Re: Kyosho mint green paint
Post by Dangeruss »
If you don't get anywhere on finding an acceptable green you can always take a wheel to an automotive paint supplier near you (PPG, Dupont, etc.) they'll scan it with a spectrometer then sell you that color single stage enamel in a ready to spray aerosol can.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
That's excellent advice.
You can prime lexan with Tamiya PS-55 Flat Clear which will allow enamel to bond to lexan.
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
It may be worth contacting Kyosho USA. They may be able to provide. Does the manual show it?
- limestang
Elkcycles
Has thanked: 234 times
Been thanked: 211 times
Post by Elkcycles »
The closest I have found off the shelf is Montana Gold in color code 6130 - Malachite.
It is an acrylic graffiti paint available from art supply stores, although you can also get it from Amazon. The green wing shown is from the Javelin mint cage set. The paint itself is flat, which doesn't matter inside a body, but backed with white it is a decent match.
timjz
Has thanked: 38 times
Been thanked: 50 times
Post by timjz »
Elkcycles wrote: Wed Apr 30, 2025 10:06 pm The closest I have found off the shelf is Montana Gold in color code 6130 - Malachite.
Going to give that a try. Thanks!
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
limestang wrote: Wed Apr 30, 2025 9:30 pm It may be worth contacting Kyosho USA. They may be able to provide. Does the manual show it?
- limestang
The official colour according to Kyosho is:
I think the video Akira Kogawa did on the Mid 87 included the actual paints he used to mix the colour, which were all airbrush paints.
I would look through build videos on youtube, I'm sure someone will have found a similar colour.
HS-YZ250
Has thanked: 178 times
Been thanked: 155 times
Post by HS-YZ250 »
HOw well does that seem to hold on lexan? And do you have a wheel to set it next to?
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
Elkcycles
Post by Elkcycles »
@HS-YZ250
The paint is an acrylic, so it is flexible like lexan paint. Adhesion is good, but you want to work several light coats. I haven't sprayed the body yet, but did a few soda bottles. I was practicing with white backing and will try silver next. My plan is to do an RB5 SB or DB in this paint scheme first. I have a spare SB body to try if I have a few minutes this weekend.
HS-YZ250
Post by HS-YZ250 »
Elkcycles wrote: Thu May 01, 2025 3:55 pm @HS-YZ250
Would backing it with a light yellow be worth a shot?
Losi JRX Pro SE
Kyosho Rocky
