JCR Molded Wings
- Has thanked: 26 times
- Been thanked: 4 times
JCR Molded Wings
I'd like to pick up a couple of the JCR molded wings that I've seen quite a few members use (it seems Masami used them often), but I'm not seeing the one's with the shorter vertical stabs anywhere. I know Ruben at Rubrix sells them, but they're the taller variety. For those running these, are you just cutting them down, or did they provide alternative versions at one point in time? I'd make a right mess of it if I tried to cut one down, so I'm hoping they're still floating around somewhere.
Thanks!
Thanks!
- RogueIV
- Has thanked: 2135 times
- Been thanked: 1100 times
Re: JCR Molded Wings
They only sell the one style as far as I know. They are easy to cut if desired.Ty89m wrote: ↑Thu Apr 24, 2025 10:06 pm I'd like to pick up a couple of the JCR molded wings that I've seen quite a few members use (it seems Masami used them often), but I'm not seeing the one's with the shorter vertical stabs anywhere. I know Ruben at Rubrix sells them, but they're the taller variety. For those running these, are you just cutting them down, or did they provide alternative versions at one point in time? I'd make a right mess of it if I tried to cut one down, so I'm hoping they're still floating around somewhere.
Thanks!
That's what I was afraid of. I'll make do with what's available, but I do wish I could at least track one down that matched the dull-orange you see on something like the Masami's 93 Yokomo.
- RogueIV
I'd get a white one and dye it. Like i said trimming them is pretty easy the nylon is soft and could even be carefully cut with body scissors.
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
If you want the wing modified, I am happy to do it for you. Just ship it my way, let me know how you want it, and I will send it on to you. PM if you are interested.
- 727 Views
Last post by mrlexan
- 923 Views
- 636 Views
Last post by Volumiza
- 25 Replies
- 2882 Views
Last post by a01butal
- 1505 Views
Last post by Northy
- 1413 Views
Last post by Brandon G
- 1327 Views
Last post by dldiaz
- 1018 Views
Last post by mikedealer
