Ayk resto Project
Ayk resto Project
i have been working on this AYK buffalo project for a little while, cleaning & polishing this old buggy when i bought it i was expecting it to come in better condition.
I have ran in to a problem i can't fix. The front suspension mounts came striped i tried filling it with Jb weld then drill & tap it, works for a minute then it just lets go. These are the last pieces of the buggy i need to finish. I made a rear suspension arm mount from cutting a scorpion roll bar and drilling though the side for the pin, work's great and looks good to i have attached a picture.
I plan on using yellow kyosho assault wheels for the project & a optima body.Any way if any body has two front pieces i would gladly pay for these or if theres any parts i have i could trade just pm me.
thanks brandon
thanks brandon
- Attachments
- DSC06488.JPG (149.02 KiB) Viewed 2172 times
- DSC06489.JPG (152.16 KiB) Viewed 2171 times
- DSC06491.JPG (153.73 KiB) Viewed 2149 times
- DSC06490.JPG (153.65 KiB) Viewed 2145 times
Re: Ayk resto Project
update on my progress...
- Attachments
- DSC06493.JPG (152.84 KiB) Viewed 2108 times
- Has thanked: 11 times
Damn I love these things - just cant get enough of them.
Kyosho Scorpions and these things are works of art.
Keep up the good work - the effort is well worth it mate.
Cheers
Darryn
Cheers
Darryn
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
First things first: your resto is looking very good, car looks better than new now!sk7 wrote:I have ran in to a problem i can't fix. The front suspension mounts came striped i tried filling it with Jb weld then drill & tap it, works for a minute then it just lets go. These are the last pieces of the buggy i need to finish.
I think you'd have better luck using some epoxy glue instead of the JB weld, let it dry enough, drill and tap like you did... I'm afraid you'll have a very hard time sourcing these two parts alone, good luck and don't give up!
Come and visit the stable
You are right about those parts indeed!
I had 4 cars - new built that needed only these parts ....I got sick of trying to find them, so I parted out the cars to fund other projects. They are very very hard to find.
Oddly enough - a friend who has access and the skills on a lathe said it would not be too hard at all to replicate the parts.....now he tells me!
Cheers
Darryn
Cheers
Darryn
well i have tried a local welding shop to tig weld up the 3mm holes so i can drill and tap them but they melted one piece so i have made these short rear frt. arm mounts from a old 7mm kyosho optima rail i had left over , used the orignal part as a guide then cut and drilled and tapped these two pieces they fit nice and tight now, so i polished them up.take a look..
well as i keep repairing this buggy i decided to tap out the frt mounts to 4mm instead of the 3mm which was a perfect idea, the result is a tight fit and it worked perfectly.Some pictures of tonights progress.
- Attachments
- DSC06503.JPG (147.66 KiB) Viewed 1870 times
- DSC06499.JPG (153.44 KiB) Viewed 1934 times
- Dr. Robotnik
- Has thanked: 7 times
- Been thanked: 42 times
Another option for repairing the threads would be to buy a 3mm HeliCoil threaded insert kit. The parts will be good as new after that.
Well i have finally mounted the wheels, It's slowly getting there i have noticed that the spindles move about a inch alllowing the wheel to "flop" around kind of makes the wheel seem sloppy,It's like there play in the lower arm where the spindle sits, Is this normal .I know a few of you guys on here have this buggy. Just unsure if it normal or not. Here is a picture .
- Attachments
- DSC06511.JPG (145.06 KiB) Viewed 1854 times
- Asso_man!
the "flop" thing is totally normal, it's due to the upper link config. it's the same on mine
Just a little Sunday update the chassis work is almost done just need some dogbones then finished , i have started on the body , it was a mess with drilled holes and cracks. I have decided to paint on top and repair as needed here's a few pics at least the body work and 1 st coat of primer is done. I am going to sand it and re prime it just to make sure it's right before paint.
- Attachments
- DSC06514.JPG (137.3 KiB) Viewed 1761 times
- DSC06518.JPG (152.59 KiB) Viewed 1760 times
- DSC06516.JPG (151.48 KiB) Viewed 1760 times
- terry.sc
- Been thanked: 157 times
If you are happy with the body style you can get a replacement as it is a Kyosho Optima body and repros are available from http://www.kamtec.co.uk
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Bling!
Nice job!
I'd finsih it off with chrome decals, or maybe a black and yellow paintscheme: no degrades, just crisp lines.
Nice job!
- bearrickster
Very nice job I love the old cars they looked more like real cars. not like todays cars that have no style.
- 4305 Views
- 30 Replies
- 3330 Views
Last post by Bormac
- 1810 Views
Last post by GJW
- 23 Replies
- 4677 Views
Last post by DennisM
- 1388 Views
Last post by Ayk Viper
- 28 Replies
- 4933 Views
Last post by stickboy007
- 1434 Views
Last post by shoman24v
- 1092 Views
Last post by hawgfanman
