Optima Mid '87 Worlds Diff Adjustment
- Has thanked: 17 times
- Been thanked: 24 times
So I just finished the build ... only took about 8 months! One thing that's already really annoying me is how hard it is to get to the diff for adjustments. You have to remove the wheel, shock, and actually remove screws instead of a body clip to get the gear cover off. Maybe it's a pipe-dream, but anyone know of an aftermarket solution to this, or some workaround that could speed this up?
- silvertriple
- Has thanked: 750 times
- Been thanked: 1324 times
Re: Optima Mid '87 Worlds Diff Adjustment
You don't need to do this way : the hole to put the Allen key is accessible, and once you have locked this side, you just have to use the wheel on the other side to tight/untight the diff
- 19 Replies
- 2343 Views
- 64 Replies
- 10342 Views
Last post by HS-YZ250
- 19 Replies
- 9146 Views
Last post by lin6499
- 3189 Views
Last post by Bo Wallen
- 52 Replies
- 13522 Views
Last post by HKS_TRD
- 1953 Views
- 68 Replies
- 23182 Views
Last post by Garage Hack
- 22 Replies
- 7626 Views
Last post by j0pp3
