gear chart or pinion advice for Losi JRX-Pro
Tucsonan
Has thanked: 98 times
Been thanked: 60 times
Post by Tucsonan »
Ia there a good gearing guide for JRX-Pro builds with modern brushless motors?
I'm finishing work on my JRX-Pro and adding a 21.5 turn LRP motor with a Hobbywing XR10 JustStock esc. I haven't been able to find a good gearing guide for this combo. Based on the factory manual an old brushed 27 turn would take a 23 tooth pinion and 86 tooth spur gear. Absent any better info that's what I'll go with for the 21.5 turn brushless.
Thanks
Dirtburner
Has thanked: 61 times
Been thanked: 123 times
Re: gear chart or pinion advice for Losi JRX-Pro
Post by Dirtburner »
I'd say you'll be closer to a 33t pinion than a 23t.
Remember those gearing recommendations in the manual are for 2.0" wheels, NiCd and 4-minute races.
I believe the LRM trans is 2.18:1 ratio.
86/23 x 2.18 = 8.15 FDR
86/33 x 2.18 = 5.68 FDR
Will a pinion that big fit?
RogueIV
Has thanked: 2139 times
Been thanked: 1100 times
Post by RogueIV »
I run a 30t on mine when using the 21.5.
Tucsonan
Post by Tucsonan »
Thanks guys. I was able to fit a 30T pinion easily. The JRX-Pro is now all wired up and ready to run. I haven't gotten it out to a park yet but it does some mean burnouts on my carpet with the orignal Losi tires :lol:
Has thanked: 357 times
Been thanked: 470 times
I'm at 75/31 with a HW stock spec G2 and Reedy SP5 21.5 with 47* timing on blinky with a motor fan with my Jrx Pro- runs around 120* at 5 min on our silly putty type clay offroad track
Return to “Losi Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
