Resurrect NiCd pack
Lizardking
Has thanked: 17 times
Been thanked: 28 times
Resurrect NiCd pack
Post by Lizardking »
I’m trying to resurrect this old NiCd pack. Cleaned it up and gave it a few charge-discharge cycles. I remember these matched cells going for $60-$80 back in the day. Seems like it tops out at 800mah and it should be 1400mah. Any suggestions on bringing it back?
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: Resurrect NiCd pack
Post by JosephS »
Beyond anything drastic try doing a series of trickle charges and full discharges . If you see the capacity going up it may just need some action to come back.
I have tried ‘jumping’ unresponsive nimh packs with short high voltage charges with limited success.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
That was the trick, shock the cell with 12v to try and break up crystallisation. Zapping the cell with reverse polarity also seems to ring a bell.
Has thanked: 269 times
Been thanked: 2094 times
I also recall something about freezing the pack to help break up crystallization.
JosephS
Post by JosephS »
RC10th wrote: Tue Aug 20, 2024 4:19 am That was the trick, shock the cell with 12v to try and break up crystallisation. Zapping the cell with reverse polarity also seems to ring a bell.
Be careful with revere polarity. I managed to reverse the polarity of a lead acid battery so now my kids power wheels goes in reverse when they floor it.
Has thanked: 2605 times
Been thanked: 2979 times
JosephS wrote: Tue Aug 20, 2024 4:49 pm
I've heard that Power Wheels use 540 size motors. That thought makes me daydream about making a Power Wheels RC. 😁
Frankentruck wrote: Tue Aug 20, 2024 4:53 pm I've heard that Power Wheels use 540 size motors. That thought makes me daydream about making a Power Wheels RC. 😁
They already make them. Kids can sit in them while someone else controls it.
Interesting.
I would have to do my own conversion. I should have kept my son's Jeep.
morrisey0
Has thanked: 87 times
Been thanked: 1853 times
Post by morrisey0 »
It's a 40 year old battery, using 50+ year old technology. Let it RIP. It is a very nice looking pack, and would go great in a shelfer. For a runner, maybe upgrade to 30+ year old NiMH technology. :D
What is that?
JosephS
Post by JosephS »
juicedcoupe wrote: Tue Aug 20, 2024 5:22 pm
I have one of those. Upgraded it to LiFe. Without a kid and no lead acid battery they are quicker then you would expect. Looks to be close to a 550 size. Didn't upgrade the motor out of fear or burning out the drive board.
HS-YZ250
Has thanked: 178 times
Been thanked: 155 times
Post by HS-YZ250 »
Frankentruck wrote: Tue Aug 20, 2024 6:01 pm What is that?
Fuse? I remember they didn't always have the solder drop fuse.
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
morrisey0 wrote: Tue Aug 20, 2024 5:45 pm It's a 40 year old battery, using 50+ year old technology. Let it RIP. It is a very nice looking pack, and would go great in a shelfer. For a runner, maybe upgrade to 30+ year old NiMH technology. :D
My sentiments exactly. From what I can see, it appears to be a fairly decent looking display battery. :)
Brendan2904
Has thanked: 268 times
Been thanked: 258 times
Post by Brendan2904 »
Lizardking wrote: Mon Aug 19, 2024 7:07 pm I’m trying to resurrect this old NiCd pack. Cleaned it up and gave it a few charge-discharge cycles. I remember these matched cells going for $60-$80 back in the day. Seems like it tops out at 800mah and it should be 1400mah. Any suggestions on bringing it back?
I tried to do this exact same thing and had little success. Best bet is to just get some nimh batteries and retire the old ones.
RC10th
Post by RC10th »
NiCd's generally aren't affected by being stored for long periods in a discharged state. Old race packs used to be stored with battery bugs attached to keep them fully discharged. The NiCd is far better than the NiMh for devices that rarely get used.
NiMh on the other hand would be ruined by sitting discharged for long periods. Also keep in mind that the high capacity NiMh cells also started getting physically larger so be careful if you do chose NiMh cells.
I would charge and discharge the pack a few times, it will likely false peak quite a few times, so if your charger has a peak detection lock out feature set it so the pack gets a decent charge, or temporarily lower the peak sensitivity. Keep an eye on cell temps while charging this way. Also warming the pack will help reduce false peaks and help the pack take a charge. After discharging put the battery on a equalizing tray to bring all the cells down to the same voltage before charging. You'll know the pack is taking a charge when it gets warm, if one cell is getting really hot and the others are cold/luke warm then you may have a problem.
Do this a few times and you should notice the pack performance increase.
From memory some of the fancy chargers from back in the day had a buzz mode which was hard on cells but was designed to break up crystallization within the cell and remove their memory. The theory of the 12v zap method from a car battery was to "blow" the crystals off the electrodes inside the battery. Many batteries can be saved but some cells cannot, they won't be as good as brand new but make good practice packs. If you have multiple packs you can swap dead cells out.
