** Build of the Month Contest - August 2024 ** - Winner - kandkhobby13
Moderator: scr8p
- Has thanked: 36 times
- Been thanked: 1318 times
Open To Any Manufacturer!
OK, this will be the thread for the August 2024 Build of the Month Contest.
GOOD LUCK!!!
** Place Holders **
GOOD LUCK!!!
** Place Holders **
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1979 times
Re: ** Build of the Month Contest - August 2024 ** - Winner - kandkhobby13
The year was 1987. I got my second ever hobby grade r/c, the Tamiya Thunder Shot for Christmas. This is of course a re-release, but the CD is original, received the same Christmas. Jammed it with my cousins while we built the T Shot. Raced it hard and lost a lot before getting my TQ10, which I also lost a lot with. And I can finally put the rumors to rest. Yes, it does have Hyper Cam engineering.
- TheDiamondOne
- Has thanked: 2077 times
- Been thanked: 588 times
- kandkhobby13
- Has thanked: 27 times
- Been thanked: 39 times
I started with an ORIGINAL AE Graphite chassis, and built up from there to have a 'modernized' durable racer.
13mm Kashima Fox shocks, 3.5mm ball cups & Titanium turnbuckles, B6 rear wing mount, JC Racing Retro case with a B6 gear diff, Factory Works steering kit, Dragon Punch RC shorty Lipo mount & Carbon towers, & all Titanium/Aluminum hardware.
Thanks for looking!
Thanks for looking!
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Picked up this as a partial slider and pieced it back together, mostly when parts that I already had.
A stamp, modified for inline battery, DS servo saver, Factory Works towers and transmission brace, and Tamiya turnbuckles (weird, right?).
Body is a JConcepts Protector with reproduction Cox Bandido wing. Wheels and tires are JConcepts as well.
Electronics consist of Novak esc and receiver, Royal Titan mini servo, and a Reedy stock motor.
Click on pics for better resolution.
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
3racing Mini MG Evo. Mini 1/10 scale FWD car.
- Been thanked: 258 times
Team Associated sc6.4.
FloTek body from a few years ago.
Go ahead and get your pics up.
- LowClassCC
poke pokeTHEYTOOKMYTHUMB wrote: ↑Sun Aug 04, 2024 3:34 pm Well, I'll be the first in the pool. Come on in fellas, the water is piss warm but the beer is ice cold!![]()
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
Wow, that is a huge steering linkage! The steering servo that far back is really wild. I guess that's where there's room and then weight balancing, etc.
- LowClassCC
Ya. The worst is that is actually the third body i bought for the car as the others were just too low to clear. I still ended up having to cut out the back window to clear. i really didnt want to go with a mini cooper style body.Frankentruck wrote: ↑Mon Aug 12, 2024 10:51 pmWow, that is a huge steering linkage! The steering servo that far back is really wild. I guess that's where there's room and then weight balancing, etc.
- Has thanked: 1782 times
- Been thanked: 858 times
If it seems slow, try installing a pinion gearLowClassCC wrote: ↑Sat Aug 17, 2024 8:51 pmYa. The worst is that is actually the third body i bought for the car as the others were just too low to clear. I still ended up having to cut out the back window to clear. i really didnt want to go with a mini cooper style body.Frankentruck wrote: ↑Mon Aug 12, 2024 10:51 pmWow, that is a huge steering linkage! The steering servo that far back is really wild. I guess that's where there's room and then weight balancing, etc.
- LowClassCC
that old motor on my dyno with a full 2s lipo spins 87k rpm, the air off the motor shaft alone makes it faster than it needs to be.1911Colt wrote: ↑Mon Aug 19, 2024 7:53 amIf it seems slow, try installing a pinion gearLowClassCC wrote: ↑Sat Aug 17, 2024 8:51 pmYa. The worst is that is actually the third body i bought for the car as the others were just too low to clear. I still ended up having to cut out the back window to clear. i really didnt want to go with a mini cooper style body.Frankentruck wrote: ↑Mon Aug 12, 2024 10:51 pmWow, that is a huge steering linkage! The steering servo that far back is really wild. I guess that's where there's room and then weight balancing, etc.I have one on all of my cars.
Users browsing this forum: DotNetDotCom.org [Bot],
Mojeek [Bot] and 2 guests
