Problem Slicing / Printing Accurate Inside Diameters
- morrisey0
- Has thanked: 80 times
- Been thanked: 1804 times
This one is a little weird, and it is throwing me for a loop. Let me just let the examples I have printed the last couple of days ask the question.
Basic 12mm pin / hex wheel adapter in varying heights. Cross section prints out 11.99-12.02mm, and heights come out within .1mm of design. My inner diameter is designed at 4.8mm, and it comes out ~4.45mm. I adjust the design out to 5mm, and they print ~4.6mm.
Then some very basic spacers I needed today. 12.5mm OD, 9.6mm ID. Again, OD and height come out just fine, but ID of parts is ~9.4mm.
They don't seem to be elephant-footing, and that would screw up the OD also. Everything seems to be just dandy except for IDs. Ideas?
Machine is a Bambu X1-Cardon. Filament basic PLA.
- Frankentruck
- Has thanked: 2545 times
- Been thanked: 2878 times
Re: Problem Slicing / Printing Accurate Inside Diameters
What size nozzle are you using? Have you tried a smaller nozzle?
- silvertriple
- Has thanked: 739 times
- Been thanked: 1269 times
I generally do the inside diameters at +.1mm and if not perfect I use a drill bit at the rigth diameter, with my hand (and this is also valid for powder base printing process).
And generally, the smaller the diameter is, the more there is chance that drilling is required...
There is also a setting X-Y hole compensation in Bambu Studio that I suppose is designed for this, but I never used it.
- Has thanked: 2735 times
- Been thanked: 2246 times
To do it properly then use the x y hole expansion in the slicer but this means calibrating I'd guess , it's usually simper to just adjust it in the middle as you have , it's just trial and error , from what I gather it's kind of a differential effect that causes it , it means the outside of the circle is more spread out but the inside is more compressed so it squishes inward .
- morrisey0
So far, an X-Y hole adjustment is the fix. A little further explanation here: https://wiki.bambulab.com/en/software/bambu-studio/xy-hole-contour-compensation I dialed it in to about a +.15, and my two current parts are looking much better. I will keep a closer eye on it in the future to see if I need to change it with different materials or anything. Thanks for the help!
- 1678 Views
Last post by RichieRich
- 515 Views
Last post by Phin
- 651 Views
Last post by aip47-2008
- 1779 Views
- 2080 Views
Last post by Smooth
- 2910 Views
Last post by j-sou
- 2137 Views
Last post by LoCoCNC
- 5136 Views
Last post by GreenHell
