Wheels for a Wild Willy?
- Brandon G
Probably more appropriate in the Clodtalk, but oh well.
Will Midnight Pumpkin wheels fit on the Wild Willy 2? Tires the same size as well?
Thanks!
Thanks!
- Synergy
- Has thanked: 127 times
- Been thanked: 72 times
Re: Wheels for a Wild Willy?
The WW2 wheels are a hex fit, the pumpkins aren't so they won't be a direct fit you will have to do some conversion work but I don't know to what degree
Here's my TC Showroom
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Ferreti's right. You would need some really long axles in the rear to make it work.
- shodog
- highwayracer
- Been thanked: 6 times
Are you willing to modify the pumpkin wheels. You can grind down the wheels so that only about 1-2 mm of the rear bolt patern is left. you can then get a hex to blackfoot adapter.
I don't know what the wild willy axles look like. Do they have a pin that holds the hex? If so, just get rid of the hex and put some blackfoot/hornet parts (I don't know what the parts are called...the ones that slide over the rear axle).
The last option would be to get some A&L rear axle extenders for kyosho cars. This was used in conjunction with their truck wheel conversions.
hope this helps...
highwayracer
hope this helps...
highwayracer
- Brandon G
See's gold insert aluminum wheels for the pumpkin.
Was hoping they fit on the WW2. I guess I could get the rear hub adapters and the offset nuts. All of a sudden this is getting more complicated than I originally hoped. If I remember correctly, the hexes have a crosspin behind them. Are the tires the same diameter? Offset would be my next question...
- shodog
To get these to work, you would have to mill off the backside of the hub on the wheel. Not terribly hard if you have access to a mill. I had planned on doing up a set of wheels my WW2 also.
- Been thanked: 12 times
bngiles wrote:See's gold insert aluminum wheels for the pumpkin.
I'd love to have a set of those, I would put them where they belong, on a gold lunchbox:
http://www.tamiyausa.com/product/item.php?product-id=49459
there are wheel wideners for the tlt that might work. they are basically really long axles that they put a spacer on. you could just drill a second pin hole closer to the dogbone side , and that would give you more room for the hub adapters and wheel.
something like this:
http://cgi.ebay.com/TOBEE-CRAFT-TLT1-WIDE-TREAD-KIT-16MM-TAMIYA-TLT-1-42980_W0QQitemZ300211904120QQihZ020QQcategoryZ34061QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That would keep you from having to modify the whels.
- highwayracer
If that's the size of the drive cup, you can probably use axles from the re-release frogs and drill a hole. Another option (but rare) would be to find the clamping rear (hub thing) for a blackfoot. Thorp makes a set that's usually anodized in red.
regards,
highwayracer
regards,
highwayracer
- 887 Views
Last post by Jirka
- 1392 Views
Last post by Lowgear
- 1036 Views
Last post by rccars4sal
- 345 Views
Last post by Brendan2904
- 789 Views
Last post by airdreams1
- 1092 Views
Last post by bearrickster
- 4399 Views
Last post by cooltoys
- 1190 Views
Last post by tizeye
