My next dumb question
- Has thanked: 2759 times
- Been thanked: 2250 times
So I want to order some Fan RC reproduction RC 10 gold shocks but I'm surprisingly ignorant considering my length of forum membership, they list them in inches and I'm fine with that bit but is it the throw they are measuring ? I'm planning on fitting them to a Mardave meteor and it looks like the same length as a stock 6 gear will do the job but I just wanted to be sure before ordering the wrong parts , very grateful for any and all help .
- silvertriple
- Has thanked: 750 times
- Been thanked: 1324 times
Re: My next dumb question
Imperial units are a nightmareDadio wrote: ↑Thu Jun 20, 2024 3:53 pm So I want to order some Fan RC reproduction RC 10 gold shocks but I'm surprisingly ignorant considering my length of forum membership, they list them in inches and I'm fine with that bit but is it the throw they are measuring ? I'm planning on fitting them to a Mardave meteor and it looks like the same length as a stock 6 gear will do the job but I just wanted to be sure before ordering the wrong parts , very grateful for any and all help .
- Has thanked: 1129 times
- Been thanked: 3919 times
The length listed is how associated refers to them so it is quite confusing for sure.
The original rc10 with short front arms came with .56 front and 1.32 rears, and the rears used tubing or spacers (5/8") to limit travel
The CE/Team cars came with .71 front and the same 1.32 rear limited
The world's car came with the same .71 but in the rear uses 1.32 bodies and 1.02 shafts instead of limiters
Measured c/l of shock cap hole to c/l of ball end:
The .56 measures about 63mm
The .71 is going to be around 69mm (nice)
The 1.32 limited is around 88mm.
The 1.32 without limiters ballpark 103mm
Thats not a problem , when I was a boy i learnt inches ,feet , rods ,poles and chains , then it was both imperial and metric , towards the end only metric , so i have that weird system in my head where if its small its mm then inches , followed by feet then meters then miles , all I can say is it works for mesilvertriple wrote: ↑Thu Jun 20, 2024 3:59 pmImperial units are a nightmareDadio wrote: ↑Thu Jun 20, 2024 3:53 pm So I want to order some Fan RC reproduction RC 10 gold shocks but I'm surprisingly ignorant considering my length of forum membership, they list them in inches and I'm fine with that bit but is it the throw they are measuring ? I'm planning on fitting them to a Mardave meteor and it looks like the same length as a stock 6 gear will do the job but I just wanted to be sure before ordering the wrong parts , very grateful for any and all help .![]()
Thanks mate that is just what I needed .GoMachV wrote: ↑Thu Jun 20, 2024 4:18 pm The length listed is how associated refers to them so it is quite confusing for sure.
- silvertriple
Where it's really bloody confusing it's when they are measure in fraction of an inch... That's where I'm lost... So far the only car I worked on in Imperial unit was the SG Gemini SLX, and I have my assumption that some parts got redesigned (and set in metric) when it came to be slightly amended by SG Racing Cars, because it's definitely a mix between metric and imperial...Dadio wrote: ↑Thu Jun 20, 2024 4:20 pmThats not a problem , when I was a boy i learnt inches ,feet , rods ,poles and chains , then it was both imperial and metric , towards the end only metric , so i have that weird system in my head where if its small its mm then inches , followed by feet then meters then miles , all I can say is it works for mesilvertriple wrote: ↑Thu Jun 20, 2024 3:59 pmImperial units are a nightmareDadio wrote: ↑Thu Jun 20, 2024 3:53 pm So I want to order some Fan RC reproduction RC 10 gold shocks but I'm surprisingly ignorant considering my length of forum membership, they list them in inches and I'm fine with that bit but is it the throw they are measuring ? I'm planning on fitting them to a Mardave meteor and it looks like the same length as a stock 6 gear will do the job but I just wanted to be sure before ordering the wrong parts , very grateful for any and all help .![]()
- 934 Views
- 554 Views
Last post by Dadio
- 1901 Views
Last post by morrisey0
- 1607 Views
Last post by Eau Rouge
- 1979 Views
Last post by tamiya_d1_junky
- 799 Views
- 1268 Views
Last post by knucklebuster
- 959 Views
Last post by rc10johnny
Amazon [Bot] and 8 guests
