Need this car identified
- martinthegenius
Hey, i need this car identified, not sure what exactly it is, front suspension has a different suspension peices then orriginal, original looks like rear. I have all the parts for this car intact except for one main tranny gear, wel get to that later.
I have all the parts to make it go, may be a little ugly till paint, cleanup, and rebuild, but my main tranny gear, one half of the differential i believe, is chewed up, and it doesnt run right. I need this gear, trade options after the picture. If you can identify the car, please let me know, and if you know where to buy the part strait up (not ebay, my dad doesnt like ebay) like tower hobbies, let me know. If you know what car it is and have the part, i will make the following trade options.
If you have a spare of the top gear in the picture above, i can offer you the folowing:
-$10+ shipping
-Any stock black plastic e/tmaxx parts unoppened maybe, oppened but never used, or open and slightly used (my uncle poured hundreds to make my emaxx all aluminum, and i have virtually every plastic part unused lying arround.
-this entire car, w/out electric (servos, radio, engine), works great, but has rear suspension problem, dirty, needs paintjob for certain parts, you must provide shipping for this option -or if your generous, and just want to give the part to me
-or as a last resort, ill give you all of the parts i have for this car in exchange for any rc10 parts, stealth tranny for orriginal rc10
pm me for any trade options, btw, all aluminum parts on this car were hand filed based on pictures according to the orriginal owner who i have lost contact with
-$10+ shipping
- mrlexan
- Been thanked: 12 times
Re: Need this car identified
The bottom one is a Futaba FX-10. The top looks to be a Kyosho Optima knock off, don't have a clue what it is.
www.gojammedia.com
www.gojammedia.com
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
The top one is a Great Vigor Beagle. Spares weren't available when it was new, thankfully it was a copy of the Kyosho Optima so parts for the Optima will fit. A Kyosho optima diff gear will fit, part number OT-27. You won't find them in any shop though as they haven't been made for at least 18 years, ebay is your only source.
- martinthegenius
crap was afraid of that. Ill see if i can sell the whole lot, cause the thing is useless w/ a chewed up diff gear, except for spare parts
- Been thanked: 42 times
You just need the outer gear right? I'm pretty sure I've got at least one. I'll send you a PM after dinner...
- martinthegenius
Thank you so much man, this car meant a lot to the original owner, I would love to see it running again.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
I can maybe help too, and towerhobbies might have a part that could work also. Let me know if you're not getting out of trouble.
- highwayracer
- Been thanked: 6 times
The only problem with the beagle is that the arms are too short or the dog bones are too long. When you set up the camber to the proper specifications (0 to -2 degrees negative) the dog bones bind. Most of the ones I've seen (including the one I built) had to have a few degrees of positive camber.
As far as that gear goes i believe an ultima one also worked on the optima.
I only have one extra and it's for my ultima after I run my mamba through it. lol
2nd place is just the 1st loser
- Mr. ED
that's correct: the optima just has a different half on the other side: with teeth for the chain
about those dogbones: which length are the originals, too long says highway racer, but what does it mean?
Can you measure them from crosspin to crosspin?
- highwayracer
I have a new pair of front beagle arms...so I'll compare that to the optima arms that I have.
regards,
highwayracer
regards,
highwayracer
Hello, I've got a NIb Beagle and I've checked the arms and they are the same as the Optima. can send a scan of the manuel if needed.
Cheers Bullfrog
Cheers Bullfrog
- highwayracer
Bullfrog wrote:Hello, I've got a NIb Beagle and I've checked the arms and they are the same as the Optima. can send a scan of the manuel if needed.
Cheers Bullfrog
Thanks for the info Bullfrog...
The front and rear hubs are pretty much identical to the optima. So, the issue must be somewhere in the drivetrain (axles, dog bones, differential).
regards,
highwayracer
- 3659 Views
Last post by Ayk Viper
- 912 Views
- 2935 Views
Last post by railey72
- 1448 Views
Last post by templeofspeed
- 2796 Views
Last post by V12
- 3558 Views
- 1254 Views
Last post by Mr. ED
- 1026 Views
