AE Vintage connectors modern replacements Associated 3740,3505
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
This is a place to keep notes as I keep looking this up.
With the 40th anniversary on the way others may care as well.
Connectors are based off an AMPS design
Brand TE Connectivity AMP Connectors
Product Series Commercial MATE-N-LOK
Wire Gauges Supported 14-20
Associated 3740 3 pin battery connectors
Socket https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-480305-0/15642
Plug https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-480303-0/19287
Associated 3505 2 pin Edinger battery and motor
Socket https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-480319-0/15662
Plug https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-480318-0/15664
Connector pin and socket
Gold pins are available as well
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/60620-1/15674
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/60619-1/15676
