AYK advertising both the 4x4 Viper and Boxer in 1986:
The 4x4 Viper was the first four-wheel drive buggy from AYK. Introduced in 1985 its transmission was derived from the Buffalo/Bobcat 2wd buggies and adapted into 4wd with the use of a chain drive to the front differential, all riding on a formed monocoque chassis with a fiberglass upper deck. Suspension was reminiscent of the Sidewinder with a trailing arm independent front suspension and semi-trailing arm rear with oil filled aluminum shocks appearing at all four corners. The 4x4 Viper originally came with an exposed cage as seen, though a later Viper Shuttle was offered with clear polycarbonate buggy style body.
1986 saw the release of the Boxer, the final 2wd buggy to be produced by AYK. The Boxer offered new wheels, tires and body but otherwise remained essentially unchanged from the Buffalo and Bobcat aluminum ladder frame, mono-shock double wishbone front suspension and semi-trailing arm rear design that it replaced.
AYK 4x4 Viper and Boxer Ad
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1409 times
- 69 Replies
- 9501 Views
Last post by RETRO R/C
- 2016 Views
Last post by Mr. ED
- 34 Replies
- 9426 Views
Last post by Trass
- 3394 Views
Last post by TomEG
- 2021 Views
Last post by saga101
- 1428 Views
Last post by besty22
- 3761 Views
Last post by Wahrsuul
- 2471 Views
Last post by Asso_man!
