AYK Buffalo Ad
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1411 times
AYK Buffalo Ad
In 1985 the Buffalo became the third buggy to be released by AYK. Evolving from the Sidewinder (itself an evolution of the Super Trail) the Buffalo continued AYK's mission to create a lightweight racing buggy. Still built on a square tube aluminum ladder frame the fiberglass upper chassis deck that replaced the plastic battery box on the Sidewinder was significantly shortened. The transmission was redesigned to place the motor transversely in the chassis behind the transmission. And gone was the trailing arm front suspension, replaced by a double wishbone arrangement with a sway bar and an oil filled aluminum mono-shock. The Sidewinders trailing arm style rear suspension remained with a sway bar and revised shock mounting locations. Preassembled, the Buffalo came equipped with a Magnum 600 motor and mechanical speed controller:
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
Re: AYK Buffalo Ad
That's a pretty cool buggy! Very interesting....
- Has thanked: 1782 times
- Been thanked: 859 times
Re: AYK Buffalo Ad
Very cool! And they assemble the tires for you!
- Attachments
- Capture.JPG (14.01 KiB) Viewed 379 times
- Dangeruss
Re: AYK Buffalo Ad
It's almost like I've seen the rear suspension... somewhere....
You know it's ready to run when the tires come mounted! Though, kinda puts a dent in the modern RTR vs. Kit argument...
Praised by editors, panned by racers.
- 1650 Views
Last post by scootmike
- 1464 Views
- 4222 Views
Last post by Dadio
- 1487 Views
Last post by Diggley
- 29 Replies
- 6963 Views
Last post by Scatamonky
- 34 Replies
- 9460 Views
Last post by Trass
- 19 Replies
- 3845 Views
- 1234 Views
Last post by AYKBOBCAT
Users browsing this forum: RogueIV and 1 guest
