Jrx shock cap orings
JRxJoe
Has thanked: 6 times
Been thanked: 19 times
Post by JRxJoe »
Anyone know where I can find the really thin orings used inside the shock cap? I searched all over last night and found nothing. I think it’s same size for all Jrx models.
I came across this kit but wasn’t sure if it included the oring. Any help?
https://www.amainhobbies.com/losi-double-oring-shock-cartridge-losa5015/p15205
Also found this kit to fix a couple stripped spring clamps. Hope it works.
https://www.amainhobbies.com/losi-shock-spring-clamps-cups-losa5023/p15208
Dangeruss
Has thanked: 425 times
Been thanked: 1411 times
Re: Jrx shock cap orings
Post by Dangeruss »
LOSA5015 is the double o-ring kit for the LXT ...XXT ...XXXT shocks.
LOSA5006 is the JRXT shock cap to body o-ring kit.
LOSA5023 is collars for the LXT ...XXT ...XXXT shocks but if your shock bodies are 12.5mm you'll be fine.
JRxJoe
Post by JRxJoe »
Thanks. Are you suggesting I get the A5006 kit and just use the o rings from it? Truthfully that’s all I need. I am thinking an alternative might be a thin band of Teflon tape? The orings are very very small in their thickness
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
You want Losi A-5011..that is just the orings
-Brad
Dangeruss
Post by Dangeruss »
5006 is the part number from the JRxT kit... guurgled the part number and... the 22T shares the part number... didn't see that coming. No, 22T o-rings won't fit.
But BattleTrak hit the nail on the head. 👍
JRxJoe
Post by JRxJoe »
Thanks guys.
JRxJoe
Post by JRxJoe »
Looks like those o rings are really hard to find now. Crazy prices for what remains. Maybe I’ll just use teflon tape
Dangeruss
Post by Dangeruss »
The o-rings are 12.0mm O.D. 10.4mm I.D. & .8mm thick so... a 12mm x 1mm o-ring will work... $3 a pack shipped beats messing with teflon tape.
JRxJoe
Post by JRxJoe »
Appreciate the dimensions. At the $5 for 50 price on Amazon, my great grandkids would have replacements. Thanks for the voice of reason.
Return to “Losi Forum”
