Parts ID - Losi Shock Kit
MikeyD
Post by MikeyD »
This Losi shock kit came with an RC10 parts lot i got off the bay.
Unfortunately, the bag was torn open, and clearly some parts are missing.
No, the missing parts aren't in the bottom of the box. :(
Can anyone tell me what Losi Kit these are for?
Thanks in advance!
losi shock kit.jpg (218.69 KiB) Viewed 1358 times
They look a lot like the JRX2 shocks in shodog's post, but i want to be sure.
Brandon G
Re: Parts ID - Losi Shock Kit
Post by Brandon G »
If I had to guess, I would say junior 2 or junior T. Looks like a .6" body, and a .9" body shock. Original cartridges, so they are from an older car.
aconsola
Post by aconsola »
bngiles wrote:If I had to guess, I would say junior 2 or junior T. Looks like a .6" body, and a .9" body shock. Original cartridges, so they are from an older car.
Most likely correct. the junior had the darker grey shock bodies. I will check with my nip junior-T kit to check the shock bag letter. I don't have any other NIP kits, but IIRC, the tags on the x-2 were pink with a jrx-2 logo.
The shock collars are the older skinny ones which are harder to find, good bonus score there.
highwayracer
Been thanked: 6 times
Post by highwayracer »
My guess is that those are from a jrx2 kit. You'll need the following:
1 shock cartridge: A-5006
1 spring collars (old style thin...not thick): A-5010
2 lower shock mounts for 5 link suspension: A-5010 (included with the item above)
1 long shock shaft: A-5005
2 short shock shafts: A-5004
8 e-clips (standard size)
2 4-40 x 3/8 socket head screws (for the shock collars)
hope this helps,
regards,
highwayracer
MikeyD
Post by MikeyD »
Thanks to all for the help!
Especially for the part numbers. 8)
Wish me luck finding the parts.
mrlexan
Post by mrlexan »
Looks like the lower spring retainers might be early ones as well. I have noticed that the later ones have three tooling marks in the bottom surface that are 120 degrees from one another (form a triangle). The older ones are smooth and have a glossier finidh to them. If you would like to trade those earlier lower and upper spring retainers and for a set of wide later ones, just let me know. I could also throw in all the parts you need to make a complete set.
www.gojammedia.com
MikeyD
Post by MikeyD »
Looks like these have the marks. :|
losi cups and clamps.jpg (196.89 KiB) Viewed 1281 times
aconsola
Post by aconsola »
MikeyD wrote:Looks like these have the marks. :|
the newer ones have the 3 marks on the outside flat surface, the older ones have the marks on the inside of the cup.
See the comparison here:
http://www.rc10talk.com/viewtopic.php?f=5&t=3171
mrlexan
Post by mrlexan »
What Anthony said. Interested in the trade?
www.gojammedia.com
MikeyD
Post by MikeyD »
Aaahh, I see now. :oops:
Jay, you ARE aware that I don't have the complete set?
But yes, I'm interested. PM coming your way. :)
Return to “Losi Forum”
