ID this RC10T
- Has thanked: 34 times
- Been thanked: 47 times
ID this RC10T
Recently picked this 10T up… Am I correct in thinking that this is one of the last runs of the original 10T design? Chassis is a C stamp and has all black parts as you can see.
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: ID this RC10T
Yes, later 10T's had the back arms, same as used on the T2.
Most of my 10T's ( 4 of 5) have those arms. The other has the V2 white arms.
Re: ID this RC10T
Thank you. This has been cleaned up and new shell done. Will be posting pics soon. Going to lightly run itjuicedcoupe wrote: ↑Thu May 04, 2023 1:18 pmYes, later 10T's had the back arms, same as used on the T2.
Re: ID this RC10T
for a vintage rc10t and using 15t brushed motor, what pinion do you think i should use? using 87t stock spurjuicedcoupe wrote: ↑Thu May 04, 2023 1:18 pmYes, later 10T's had the back arms, same as used on the T2.
- juicedcoupe
Re: ID this RC10T
An 18 or 19T should be close. If using lipo, I'd consider 17T.
Actual usage type will also effect this. Things like grass put more load on the motor, requiring a lower gear ratio.
And then there is the motor itself. Even when comparing motors with the same rating, they can perform and behave drastically different.
Re: ID this RC10T
That high of ratio ehh? I was thinking around 21-22t. It’s. Reedy radon 15t motorjuicedcoupe wrote: ↑Sun May 14, 2023 5:04 pmAn 18 or 19T should be close. If using lipo, I'd consider 17T.
- juicedcoupe
Re: ID this RC10T
The original 10T has a 2.25:1 transmission ratio, while newer trucks have 2.4 or 2.6 ratios. So you can't directly compare the pinion size to that of newer trucks.
As a general baseline, something in the 10-11:1 overall ratio is close for a 15T in a stadium truck.
The current Reedy Radon motors look almost identical to Integy motors. While they are better quality than the Hackmoto, Apex, etc stuff on Amazon and Ebay, they are nowhere near that of quality motors from the 90's and early 00's.
Not to discourage you, just understand that those motors won't perform or hold up as well as older Reedy (etc) motors did.
- Has thanked: 9 times
- Been thanked: 64 times
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: ID this RC10T
I remember cracking the box on a very late 10T sport truck in the hobby shop and it had the yellow 3pc wheels. The T2 was already out at that point.
Re: ID this RC10T
Some new lids for the 10tjuicedcoupe wrote: ↑Mon May 15, 2023 8:08 amThe original 10T has a 2.25:1 transmission ratio, while newer trucks have 2.4 or 2.6 ratios. So you can't directly compare the pinion size to that of newer trucks.
- 2028 Views
Last post by THUNDERSTRIKE1
- 2338 Views
Last post by VintageFanatic
- 2260 Views
Last post by ericsp2
- 852 Views
Last post by PBR Allstar
- 2499 Views
Last post by JK Racing
- 591 Views
Last post by RedScampi
- 1423 Views
Last post by slotcarrod
- 55 Replies
- 4465 Views
Last post by XLR8
