New scans added to the AE Reference Library online
The place for digital versions of miscellaneous documents.
WebSteve
Has thanked: 4 times
Been thanked: 47 times
Post by WebSteve »
I scanned the following into the Library under "Spare Parts: Offroad," "Spare Parts: Onroad," and "Reedy Motors":
Tips-for-Lexan-Painting.pdf
sp300_Reedy_Micro_Lathe.pdf
3201_12e_Front_end_Kit.pdf
3430_1_12_Diff_Inst.pdf
4110_12i_Front_End_Kit.pdf
4111_Spring_Front_end.pdf
4126_Tie_Rod_kit.pdf
4147_12i_Chas_Ride_Height_Adj.pdf
4450_1_12_Stealth_Diff_Axle.pdf
4347_Motor_Spacer.pdf
4400_12L_12LW_Front_Susp_Kit.pdf
4455_1_12_Stealth_ii_Diff_Axle.pdf
1_12_tire_horn.pdf
12LW_Susp_Arm_Assembly.pdf
6351_RC10_Rear_Antiroll_Bar.pdf
Oval_Nurf_Wing.pdf
3190_Wing_Kit.pdf
6312_Clear_Chassis_Protective_Film.pdf
6189_Sprint_Wing_Kit.pdf
7350_RC10T_Rear_Suspension.pdf
8205_RC10L_Rear_Chassis_Cross_Brace.pdf
6311_Motor_Mount_Chassis_Brace.pdf
6371_Universal_Dogbone_Driveshaft_Stub_Axle.pdf
The documents are found here:
https://apps.associatedelectrics.com/ateamapps/index.html / Vehicle Reference / Early Documents
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: New scans added to the AE Reference Library online
Post by JosephS »
How do you determine what gets added and what isn't?
Been thanked: 3917 times
Just a heads up, the 3190 wing kit link is broken- its missing the .pdf off the end of the hyperlink.
WebSteve
Post by WebSteve »
JosephS,
I am adding the content that I have in my files. If I don't have it, I can't scan it.
GoMachV,
I'll look into that next. Thanks!
morrisey0
Has thanked: 87 times
Been thanked: 1852 times
Post by morrisey0 »
Thank you so much for these!! :D
WebSteve
Post by WebSteve »
I've added more of the documents I've created in my work at AE in the first couple of decades here.
Check the front page, scroll to bottom, and click on "Reedy Catalogs, Ads, and Misc" (formerly, "Reedy Catalogs").
Phin
Been thanked: 248 times
Post by Phin »
Hey Steve, by any chance do you have documents containing info on the magnesium parts mentioned in this 1984 ad for the "Factory Team RC500 Custom Lightweight" kit? Or any info on the parts for the K&B 3.5 engine sold through Associated...like the McCoy crankshaft?
WebSteve
Post by WebSteve »
I only posted material that I personally worked on, and kept copies of, in my files. I don't have any material on those parts, sorry.
WebSteve
Post by WebSteve »
Just posted more items in the Team Associated Reference Library: Team Associated business cards across the years!
It's in the "Associated Electrics Reference Library" section, "Team Associated Catalogs & Business Cards." Link is reference earlier in this thread.
Return to “Vintage Document Scans”
