Turnbuckles
Mwildmann
Has thanked: 92 times
Been thanked: 72 times
Turnbuckles
Post by Mwildmann »
I'm not sure what you all are using for turnbuckles but I was in the market for some for my Team Car rebuild. I'm far too cheap to buy anything titanium, nor am I a good enough driver to make use of any performance gains. I wanted something a tiny bit more flashy than the universal cut-to-length Dubro ones I could find. I ran across these spiffy stainless steel ones marketed for R/C airplanes. I did a little figuring/guessing and bought 2 pairs in the 1 5/16 inch length for front and rear bulkheads and 1 pair of the 1 1/2 inch for the front steering turnbuckles, for use with slightly longer than stock RPM standard length ball cups. They turned out pretty nice IMO.
https://www.espritmodel.com/pushrod-turnbuckle-steel-secraft-440-2.aspx
Has thanked: 269 times
Been thanked: 2094 times
Re: Turnbuckles
I typically get the chrome Schumacher turnbuckles in whatever lengths I need.
Mwildmann
Re: Turnbuckles
Post by Mwildmann »
juicedcoupe wrote: Fri Apr 07, 2023 4:59 pm I typically get the chrome Schumacher turnbuckles in whatever lengths I need.
They work with the 4-40 ball cups? They are nice...
Re: Turnbuckles
Mwildmann wrote: Fri Apr 07, 2023 5:13 pm
Yes, they are M3 thread. M3 is slightly (very slight) larger than 4-40.
Mwildmann
Re: Turnbuckles
Post by Mwildmann »
juicedcoupe wrote: Fri Apr 07, 2023 5:17 pm
Dang, and here I thought I was about to contribute something helpful! :lol: When I invest in a basket case RC10T I'll be sure to give the Schumacher ones a shot.
Has thanked: 2605 times
Been thanked: 2979 times
Re: Turnbuckles
Mwildmann wrote: Fri Apr 07, 2023 7:04 pm
Those stainless turnbuckles you used are new to me and look really nice.
Mwildmann
Re: Turnbuckles
Post by Mwildmann »
Frankentruck wrote: Fri Apr 07, 2023 7:14 pm Those stainless turnbuckles you used are new to me and look really nice.
Thanks! I'm definitely happy with them.
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Re: Turnbuckles
Post by MarkyDents »
They very much resemble Tecnacraft Ti turnbuckles, and that to me is AWESOME ! Never seen them before so thank you 8)
Hey Cru ! Go balls out 8)
mikea96
Has thanked: 659 times
Been thanked: 878 times
Re: Turnbuckles
Post by mikea96 »
Yeah they look really good!
Mwildmann
Re: Turnbuckles
Post by Mwildmann »
MarkyDents wrote: Fri Apr 07, 2023 7:59 pm They very much resemble Tecnacraft Ti turnbuckles, and that to me is AWESOME ! Never seen them before so thank you 8)
My pleasure, and I agree. They have that sort-of darker hue like titanium....but only $3 a pair. I'll rock fake titanium every day of the week.
My only complaint is the slightly inconsistent machining...but I already got over it.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Turnbuckles
Post by klavy69 »
Want to thank you also. I was sorting turnbuckles last month and was putting tecnacraft in a pile when I had a really heavy one to go with them. Definitely tell the weight difference but damn they look very much alike. Now I know where to look for more to finish the stuff I found.
Mwildmann
Re: Turnbuckles
Post by Mwildmann »
klavy69 wrote: Fri Apr 07, 2023 8:45 pm Want to thank you also. I was sorting turnbuckles last month and was putting tecnacraft in a pile when I had a really heavy one to go with them. Definitely tell the weight difference but damn they look very much alike. Now I know where to look for more to finish the stuff I found.
Sorting out a whole pile of titanium turnbuckles, eh? Not a bad problem to have! Really glad to have helped out. 👍
Re: Turnbuckles
Not to be the bearer of bad news, but I believe that you'll find that you have an interference problem between these ball cups. Move the steering as you compress the suspension.
You have RPM ball cups AND RCPS/Losi bellcranks. Either one is likely to cause problems by themselves, and it's almost guaranteed with both. I personally avoid using either on a buggy front end.
You can try moving the camber links to the outer holes of the shock tower, if you have enough adjustability.
Schumacher makes a low profile ball stud that can be used at the tower to provide a little more clearance.
