Duratrax dtx-4 esc manual
BuddyS
Post by BuddyS »
Hello all,
Does any one have the manual for the Duratrax dtx-4 esc?
I know it very very similar to the Novak T4 but the adjustment pots seems to be opposite from what is mentioned in the Novak T1 & T4 manual.
Please post a pic of the dtx-4 manual if any one has one.
Thanks
Has thanked: 269 times
Been thanked: 2094 times
Re: Duratrax dtx-4 esc manual
I believe that it is a 410-M5, in a blue case.
BuddyS
Post by BuddyS »
I don’t believe it is the 410-M5 as the led and pots are in different locations. It looks identical to the T4 but in a blue case.
Yeah, I looked up a picture of it. It's pretty much identical to my T-4 and T-1.
But anyway. Pretty much all dual pot esc's setup the same way. I have multiple Novak, Tekin, Futaba, and Hitec esc's that setup the same way. You are just setting the neutral and high points.
BuddyS
Post by BuddyS »
I got it all set up and working. I was just hoping somebody here has the original manual for it.
Thanks
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
BuddyS wrote: Fri Mar 31, 2023 9:57 am I got it all set up and working. I was just hoping somebody here has the original manual for it.
Thanks
Have you checked to see if there is one posted in the archives?
BuddyS
Post by BuddyS »
Yes, I searched farther than that as well. Thanks
klavy69
Moderator
Post by klavy69 »
So, your looking for a manual just to have it? OK, if you can't find it online maybe try facebook. Theres several groups that might be able to help you out. Even if you stayed around long enough to gain b/s/t access and put in a request per the rules in the wanted section instead of out on the board you will pry get the same response as what this got. Please try to keep requests in the b/s/t area though.
Thanx
Has thanked: 1737 times
Been thanked: 1145 times
I knew I had this somewhere..... found on the weekend, so scanned. Quality is not great, as it's a scan of a photocopy from a folder..... but it is legible (I hope!).
Hope that helps!
