project 4x4 tomahawk
ok thought id start a new thread . iv done a bit of work on it today just trying to see how every thing fits. so far i have a scorpion chassie and suspension arms progress front & rear diff and chain. need to find some shorter dog fighter uni's and make some axle extensions to get the wheels out past the suspension arms and the shorten the chain to the right length. Also need to make some brackets to mount the steering and front diff , would anyone have any scorpion chassie rails as these are off scorpion that Im currently restoring
- Attachments
- P1010680.jpg (221.86 KiB) Viewed 2487 times
- P1010679.jpg (235.11 KiB) Viewed 2486 times
- Dr. Robotnik
- Has thanked: 11 times
Re: project 4x4 tomahawk
Hard task there - good on you for having a go.
I will be most keen to see how you get around the front end angle issues - like suspension mounting and the front steering knuckle arrangement.
Good luck!
Cheers
Darryn
Good luck!
Cheers
Darryn
Thanks for the interest guys sorry for the late reply.I also started a 150 m2 house extension this past weekend so I've been a little busy . anyway back on topic i don't think the front end geometry will be to bad at all everything seems to work rather well .what are peoples thoughts on sweep the front drive shafts back a degree or two for a little more clearance around the shock mounts
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
you're running into the same issues I saw.
With the trailing arms you'd actually want the dogbones or universals to go a little forward on the inside: otherwise they'll get pushed deeper into the drive cups (as far as that's even possible) when the arms tilt up. If you can get the front gearbox more forward, you'll also have more space for the steering.
For the bones you could solve it with sliders , but the steering will have to be a litttle forward of the knuckle also actually: else you get the same effect as for the dogbones. Meaning terrible bumpsteer.
You still have a hard one to tackle. Goodluck my friend.
- Mr. ED
http://www93.sakura.ne.jp/~time-tunnel/toma%20custom-05.html
http://www93.sakura.ne.jp/~time-tunnel/prog%20custom-02.html
might be useful references for you.
the axles in the second link are tobee craft hop-ups for the TLT1
I got the 12 mm extension version which will just work with the lazer ZX5R wheels, but you'd probably want a bit more offset still in the rear, unless you use a wheel with more offset.
Tobee craft makes these extensions in many different sizes
thanks ED Id always wondered what axles they were using on the progress. Google doesnt translate japanese to english very well
- Mr. ED
Hey Jasen, do you still need those rails?
I've got some stuff left over you can have cheap. It's not perfect,and definitely not seen its package in a looong time but the rails are reasonable straight again.
- KyoshoScorpionKid
- martinthegenius
OMG- I love it!!! I hate plastic on rc cars- but i can't get enough aluminum! Very beautiful sweet ride. Good luck with it.
- 115 Replies
- 14624 Views
Last post by coxbros1
- 1261 Views
Last post by tamiyadan
- 28 Replies
- 4121 Views
Last post by hibernaculum
- 2863 Views
Last post by 1300GT
- 862 Views
Last post by DennisM
- 3957 Views
Last post by klavy69
- 3824 Views
Last post by railey72
- 40 Replies
- 9628 Views
Last post by DANFROMOZ
Users browsing this forum: Mojeek [Bot],
Semrush [Bot] and 4 guests
