Tamiya "Turbo" Frog
GRRacing
Has thanked: 17 times
Been thanked: 32 times
Tamiya "Turbo" Frog
Post by GRRacing »
Classic RC10 rival, "Turbo" Frog complete. Mods inspired by re-re Turbo Scorpion. Livery inspired by Jammin Jay RC10 and Frog boxart (behind Frog) 🐸.
Custom made parts...
*Gearbox mount +10mm wheelbase.
*Rear arm hanger +10mm wheelbase.
*Rear wing mount/rear bumper/body protector.
*Front arm extenders. +20mm front width.
+Front shock towers.
*Front bumper.
*Large bumper reinforcing fiber plate.
*Stealth switch mount.
*Battery harness clip/rod.
*Rear wing.
Custom mods...
*extended rear shock length +10mm.
*Extended steering rods +10mm each side.
*Front shocks.
*Bumper mount front angle.
*Radius arm relocation.
*Front axle screwed into arm.
https://www.instagram.com/p/Ci9autQPXCn/?igshid=MDJmNzVkMjY=
Dadio
Has thanked: 2757 times
Been thanked: 2250 times
Re: Tamiya "Turbo" Frog
Post by Dadio »
I like that, pretty cool stuff.
Sprocket
Has thanked: 6 times
Been thanked: 9 times
Post by Sprocket »
How does it run?
GeneralZod
Has thanked: 150 times
Been thanked: 162 times
Post by GeneralZod »
That is a beautiful 🐸! I still need to get one after all these years. Such an iconic car.
GRRacing
Post by GRRacing »
Sprocket wrote: Sun Oct 30, 2022 1:17 am How does it run?
I've had it out with a 27t brushed stock motor and it handled it nicely. Swapping for a brushless 21.5t, then it'll really put it to the test.
graemevw
Has thanked: 7 times
Been thanked: 17 times
Post by graemevw »
I like the gearbox extension mounts. Might have to steal that idea for my modified frog!
TokyoProf
Has thanked: 563 times
Been thanked: 418 times
Post by TokyoProf »
Impressive work on the chassis and body and wing.
GRRacing
Post by GRRacing »
graemevw wrote: Tue Jan 17, 2023 1:18 pm I like the gearbox extension mounts. Might have to steal that idea for my modified frog!
Awesome! Let me know how it goes. 8)
GRRacing
Post by GRRacing »
TokyoProf wrote: Tue Jan 17, 2023 6:19 pm Impressive work on the chassis and body and wing.
Cheers! 8)
graemevw
Post by graemevw »
GRRacing wrote: Sun Jan 22, 2023 5:51 am
Will do. Finished my modified grasshopper so time to revisit the frog.
I modified the rear end to put the rear arms on bearings, and the diff has the screw mod. Main weak area is the front end. I put avante shocks on it, but it's still terrible, so I'll prob a my swap it all out for something else. I had been wondering how to give it a bit more wheelbase, and your idea is a nice simple solution. The best solutions normally are!
GRRacing
Post by GRRacing »
graemevw wrote: Sun Jan 22, 2023 7:06 am
I`ve used a shaft + bushing arrangement. No play at all now...
GRRacing
Post by GRRacing »
GRRacing
Post by GRRacing »
Sounds great 👌😎
TheDiamondOne
Has thanked: 2077 times
Been thanked: 588 times
Post by TheDiamondOne »
VERY IMPRESSED!
GRRacing
Post by GRRacing »
...cheers 👍
Return to “Tamiya Forum”
