Do you display with or without electronics?
- TokyoProf
- Has thanked: 563 times
- Been thanked: 418 times
For the shelf display folks, do you display your cars bare without any electronics? Or do you add just a motor?
- morrisey0
- Has thanked: 87 times
- Been thanked: 1853 times
Re: Do you display with or without electronics?
All my shelfies get full electronics, and are in position so that they could technically be ready to run with minimum prep (not that that would happen). The electronics are the heart of the car IMO. Without them, it would be like a museum full of 1:1 cars with no engines or drivetrains. It logically makes no sense to have a RC car [close to] RTR if it sits on a shelf, but it makes sense to me.
- Has thanked: 1129 times
- Been thanked: 3919 times
I try to add electronics but only if they “fit”. I don’t like to use placeholders, I fear I will miss finding the right components if there is something already in there. Once in a while I’ll upgrade.
Many of my new in box kits also have radio gear and electronics waiting for their eventual builds as well.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Short of a crystal (maybe), all of my comple cars are functional. My TQ10 isn't complete but I have the electronics for it.
- R6cowboy
- Has thanked: 871 times
- Been thanked: 903 times
Same, all get full electronics and ready for use. With the exception of a couple that would need to fill shock fluid, but those are meant to never be ran except for an occasional slow stroll around the basement to make sure everything is in working order.
-Jerry-
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
I'm a bit torn. I like a ready to run shelfer but I don't like servo tape and how difficulet it can be to remove. I guess I could just use minimal servo tape for a shelfer, but then it really isn't ready to run. For my runners, I try to use 3D printed holders that allow for easy electronics removal.
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
For me it largely depends on my goal with the build. None of my shelf queens will ever be run so adding electronics is just a bonus. When I do add them, they have to be from around the year the model came out. Ultimately though, it's nothing I'm going to lose sleep over.
- Has thanked: 2759 times
- Been thanked: 2250 times
Not really sure I should comment as mine all get a little run time but I'd say go the whole hog and fit period correct electronics , the only possible exception might be a car that's got a high quantity of alloy parts that have been highly polished or (not my taste but ) complete matching anodised parts that may be obscured by electronics , in that case I might even allow a clear body .
- Has thanked: 59 times
- Been thanked: 71 times
Gotta be a functional runner I reckon. Otherwise might as well be airfix or revell kit. Getting it "working" is half the enjoyment. But I'm not a collector just a dabbler and bodger.
Whatever rocks your boat
- GeneralZod
- Has thanked: 150 times
- Been thanked: 162 times
The car to me is just not complete unless it has full electronics including the battery. I try to use a functioning battery but am ok with a display only one if I am going with period correctness. I like to have the car ready to charge and go if I want to run slow laps around the office.
- Has thanked: 1782 times
- Been thanked: 859 times
I am not a "collector". All of my cars are runners except the Bosscat (long story).
That said, my advice is do what suits ya! For some, the electronics are an important part and I get that. The object is to reproduce the car in all its glory, and that would include electronics.
On the other hand, some might just really like the cars themselves. If that is the case for you, you can have a much more extensive collection for the same budget if you don't spend loads of cash on things that will never get used.
- Has thanked: 1243 times
- Been thanked: 639 times
I don't have a lot to display, but the non-runners have no electronics, nor paint on the bodies. Basically i haven't gotten around to turning them into runners.
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
Velcro works good and removes much better than the double side tape. One trick for the servo tape, rubber cement softens the residue so you can rub it clean. Usually takes a few time, but works great.Frankentruck wrote: ↑Sat Sep 24, 2022 9:46 pm I'm a bit torn. I like a ready to run shelfer but I don't like servo tape and how difficulet it can be to remove. I guess I could just use minimal servo tape for a shelfer, but then it really isn't ready to run. For my runners, I try to use 3D printed holders that allow for easy electronics removal.
- limestang
- juicedcoupe
Lighter fluid breaks down servo tape, allowing it to be removed without resorting to tools. It is also safe for plastics, unlike some other chemicals.
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
WD40 gones goo too.
- 35 Replies
- 4449 Views
Last post by RCveteran
- 2060 Views
Last post by tamiyadan
- 1486 Views
Last post by Prince Steve
- 27 Replies
- 3608 Views
Last post by jamin
- 1145 Views
Last post by RC10th
- 2363 Views
- 862 Views
- 20 Replies
- 4093 Views
Last post by Halgar
