Shapeways to the Rescue
cas22
Has thanked: 130 times
Been thanked: 249 times
Post by cas22 »
Various bits for my projects,
Really didn't like the battery set up for LiPo cells on the Optima, and Rocky, so bought these clamps to try, much more secure and well made.
Also a slightly different bell crank for my belt drive rocky conversion, takes ball ends so will be more positive than the bent wire factory set up. Been after a more elegant solution for this for ages, really need to invest it some software and a 3D Printer,
Various Losi reproduction parts for the JRX Pro, wing buttons, front bulkhead (mine was stripped) and thin shock collars to suit the first generation silver bodies,
Also have discovered these actual titanium tie rods from Ali express, 38mm x 3mm so suit a lot of applications, hard to cut down but insanely cheap, have used them on loads of builds so far, and easier to source than going through the states.
