Heresy ?
- Has thanked: 2759 times
- Been thanked: 2250 times
Heresy ?
Any guesses what this might be ?
- 1300GT
- Has thanked: 486 times
- Been thanked: 406 times
Re: Heresy ?
New lower wishbone mounting position and improved steering for the Tamiya Grasshopper/Hornet?????
And yes, it's heresy of the worst kind!
Chris.
Toys.............they are!
Re: Heresy ?
It gets worse , I'm thinking gRassC10
- silvertriple
- Has thanked: 750 times
- Been thanked: 1324 times
Re: Heresy ?
Nice work
... But may I ask if you did something for the rear end first?
Re: Heresy ?
The rear is already perfectsilvertriple wrote: ↑Fri Jul 15, 2022 8:02 am Nice work... But may I ask if you did something for the rear end first?
Seriously (or not very) I was thinking more JRX2 at the back or at least stylised around a beam axle.
- silvertriple
Re: Heresy ?
I'm not even sure what kind of frankenGrasshopper you are doing here, but I can say for sure that my Hornet imprecise driving is likely to come from the rear end even more than from the front endDadio wrote: ↑Fri Jul 15, 2022 9:07 amThe rear is already perfectsilvertriple wrote: ↑Fri Jul 15, 2022 8:02 am Nice work... But may I ask if you did something for the rear end first?
Looking forward to your progress on this one... I have a Hornet sitting there, and I'm definitely considering doing something from it, as the first purpose of it was a special yearly race for which the target is now to use the Lunchbox. I need to find a new purpose for my Hornet.
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Heresy ?
For the rear I'm planning on a JRX2 lookalike so it will probably be 4 trailing links with a panhard rod to stop lateral movement.
Re: Heresy ?
Now integrated the top camber link mount plus a dozen other minor changes .
Re: Heresy ?
Yup but for me it must cosmetically be JRX2 ish for the win, I know the JRX2 has many more links but hey ho!
- Has thanked: 100 times
- Been thanked: 205 times
Re: Heresy ?
It's looking pretty good so far, I must say those short front arms look even funnier on this then they did on the RC10.
RELEASE THE TAMIASSOSI!
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Re: Heresy ?
Even the short arms are adding to the track width, needed to get clearance to chassis so it's about 1mm wider than a stock RC10, going to have to stick some wheels on to see how it Looks, might have to play with the rear track?
Re: Heresy ?
About a million tiny changes later and the steering works albeit needing bent track rods , now just have to settle on shocks, kind of had my heart set on not cutting up the chassis but I don't think I can do it in a satisfactory way other than trimming the top the shock mounts a bit .
Now I have wheels on I think the increased front track looks fine .If a jobs not worth doing then its certainly not worth doing well.
Re: Heresy ?
Lil bit more , made a start on the rear , right now it's locked solid at the rear as I still have the original rear suspension mounts in place , the wheel base was shortened by about 15mm by the front arms so my next trailing arms will be 15mm longer to get it back to the right length , it's hard to get the camera to focus but you should get that it's got a firm nod to the JRX2 , the longer lower arms , the trailing arm mount shape , I'm quite pleased with the trailing arm mount , it's located by 4 original screw points , two are from the stock suspension mount point and the other two are for the side nerf bars , I really did want to keep the nerf bars so I may well have another revision to do , luckily the stock nerf bars are soft as noodles so might be slightly bent to fit .
- 1712 Views
Last post by Dr. Robotnik
Users browsing this forum: Bing [Bot] and 2 guests
