FINALLY, ready to start on my Trophy Truck
MONSTER
Post by MONSTER »
Ive had this for MONTHS, and have been chompin at the BITS to get started. Finally got the Wife to let me buy the Tires I needed, so here we go.
This is what I got.
Assembled, with tires. Will (eventually) get 31mm, Offset Wheels all around. These are just the only full set I had Unmounted. I'll be "working on" the Body as well. Previous owner, not much of a "detail person". :roll:
Give me some info on it. TA-01? Vintage? Is there any way to "Date" it? Pros...Cons? Whatever you can tell me would be great.
shodog
Been thanked: 91 times
Re: FINALLY, ready to start on my Trophy Truck
Post by shodog »
thats a TA-02. simliar to the TA-01 but shorter. They still sell the S-10
MONSTER
Post by MONSTER »
Whats the diff/s in a TA-01 and TA-02?
shodog
Post by shodog »
MONSTER wrote:Whats the diff/s in a TA-01 and TA-02?
This post will explain it best but basically the diffeence is 30mm of chassis length http://www.tamiyaclub.com/showroom_model.asp?cid=48983&sid=2193
MONSTER
Post by MONSTER »
White Lithium Grease "ok" in the Diffs, or better off with AE Diff Lube?
shodog
Post by shodog »
if I remeber correctly the ta-02 has a front gear diff and rear ball diff. in the gear diff, white grease would be fine but I prefer bicycle gear. in the ball dif, you want to use ball diff gease. everywhere else, lithium or bicycle grease.
MONSTER
Post by MONSTER »
"ball diff gease" would be Stealth Diff Lube? Sorry, for all the noob questions. I only have AE "Black Grease", Stealth Diff Lube, and White Lithium, but I guess I could wait to pick up something else, if need be. I want it to be right.
MONSTER
Post by MONSTER »
HOLY CRAP this thing cleaned up NICE!!!
BTW, the Stickers on the Body are in "good shape", but peeling a little here and there. Is there a certain Adhesive that can be used to stick down the loose corners?
Dr. Robotnik
Post by Dr. Robotnik »
It's pretty shiney now. Nice save...
MONSTER
Post by MONSTER »
Well, its not much fun to run right now. It makes a very loud whining noise when running, and the binding is AWFUL. If I loosen up the Housing Screws enough to free it up, the Pinion/Spur Slip real bad. I suppose bearings should take care of all the Binding, and at least a little of the Whining. But its NO good as "Crawler". If one Wheel loses the least bit of Traction, it starts spinning. So, about Locking the Diffs, I dont want to Do anything I cant UNdo. Ive heard of people Locking Gear Diff (Front) with Silly Putty, so it can be removed easily. Is there another/better way? Maybe I wont "have" to Lock the Rear Ball Diff, but if I decide to, is there a way to do it that can be UNdone, without having to buy another/parts?
MONSTER
Post by MONSTER »
Doesnt anyone have any info on NONpermanent ways of Locking Gear and Ball Diffs?
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
You had it right with the silly putty though there are tougher variants which are better if you want to really lock it down.
This car is not much of a crawler design though: too little ground clearance and way too little reduction for the tiresize.
The basic design came straight from a touringcar.
Better take it to the beach instead.
MONSTER
Post by MONSTER »
Oh yeah, I know it wont make a "real" Crawler, I just want to be able to go through a few holes and over some small hills around the yard. Right now it wont go over or through hardly anything. :roll: Im gonna try a 27T Stock Motor, Geared REALLY low. If that wont work, I'll see if I can find something with lower turns. Whats the lowest Turned Motor that can be had, that will fit in there.
Just trying have something a little "different", 8) no more than say, someones 1:1 "daily driver" 4WD might do, only scaled down.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
check out the "lathe" motors, Integy? 55 turn, I see them on evilBay regularly.
Mr. ED
Post by Mr. ED »
Check an industrial moter supplier for anything in 540 size: I picked one up from http://www.conrad.de
Don't know how many turns it has, but it has a cool 5 pole armature like the pullers in the old days. And best of all: itwas about as cheap as your standard mabuchi 540.
Return to “Tamiya Forum”
