Pro tip #6636
- civilguy
- Has thanked: 3 times
- Been thanked: 14 times
Pro tip #6636
When you are moving and have either packed away or sold every lubricant you had in the house (including the bedroom ones), diff grease makes squeaky hinges glide like new.
Jeff
Jeff
- Has thanked: 646 times
- Been thanked: 462 times
Re: Pro tip #6636
Only problem with that is long term it’ll cause the hinges to bind and wear, due to the grease holding dust, better option is a bit of graphite aka pencil lead
Dry lube = no dust attraction
- civilguy
Re: Pro tip #6636
If my tool chest wasn’t already in storage I’d have some graphite ready to roll. Luckily I’m still going through my rc stuff as it’s the most difficult to sort and subsequently part with.
Jeff
Jeff
- RC10th
- Has thanked: 50 times
- Been thanked: 1490 times
Re: Pro tip #6636
If he is moving I don't think he's too concerned with hinge longevity, lol.
- juicedcoupe
- Has thanked: 263 times
- Been thanked: 2003 times
Re: Pro tip #6636
I have a mixture that I make for fishing reel bearings.
It is made from TSI-321 and Corrosion X. However, it's main component is 99% isopropyl alcohol.
The IPA acts as a solvent and carrier fluid before evaporating. It will displace dirt and grime, leaving the lubricant.
- 1049 Views
Last post by RC10th
- 1359 Views
Last post by longboardnj
- 1049 Views
Last post by bluewormx
- 898 Views
Last post by MOmo
- 109 Views
Last post by AscotConversion
- 621 Views
Last post by mytimac
- 864 Views
Last post by markt311
- 377 Views
Last post by JosephS
