RC10L-SS Wheels and tires
erikstarcher
Post by erikstarcher »
Hi guys (and hopefully some gals), I am hoping someone here can help me out on my restoration. I am starting to rebuild my 10L from way back in the day and need some new front wheels and tires, and maybe rears as well. I have found some from CRC and BSR but I can't find any specs on the mounting.
Do all pan car tires use the same front and rear mounting?
I know the front of the 10L uses SAE bearing and the rears have 4 screws but I have not been able to tell if that is a standard across the board.
Don't want to buy new wheels just to find out they only use metric bearings and the rear screw holes don't line up properly. I have new "snowflake" rear wheels and tires but the fronts are original Associated originals and chewed up pretty good. Would love to be able to just get matching front ones. Foam compound doesn't mater because this is only going to be a shelfer.
Thanks, Erik
RPMfieldtester
Has thanked: 83 times
Been thanked: 76 times
Re: RC10L-SS Wheels and tires
Post by RPMfieldtester »
You should be good...pan cars wheels were pretty much standardized, especially 10th scale
