Bulk axle shims
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Bulk axle shims
Hey guys! I asked on the FB group but I didn't really get an answer. I'm in need of the standard 3/16 x .01 shims that are used for axle spacing. I see Amain has a 20 pack for $6 which isn't crazy, I guess. I thought McMaster might have a 50 or 100 pack. When I look for shims there, they have a set of 5 for ~$9.50. I must be looking at the wrong thing. I mean, you can get a pack of #8 washers for cheap, but will these work as well?
Re: Bulk axle shims
Shims are one thing I have not been able to find cheaply. That price from Amain is pretty good.
I saw your post but when I went to reply after refreshing my memory, well.... You know how Facebook is with finding old posts. Ugh.
Glad you popped in and I could reply.
- Has thanked: 1243 times
- Been thanked: 639 times
Re: Bulk axle shims
Custom works has a mixed size set of shims.
Custom Works 3/16" Axle Shim Kit part CSW7048,
at $4 it's not to bad for shims.
Link to the product at customworks
- RichieRich
Re: Bulk axle shims
AH! That's good assortment. I didn't see that one.JosephS wrote: ↑Sat Feb 12, 2022 12:17 am Custom works has a mixed size set of shims.
https://www.amainhobbies.com/custom-works-3-16-axle-shim-kit-csw7048/p701778
@jwscab Yeah, FB's algorithm always adjusts things so you gotta respond right then or you'll never find it again.
- Has thanked: 1153 times
- Been thanked: 624 times
Re: Bulk axle shims
That’s a big reason why forums are better than fb groups.@ jwscab Yeah, FB's algorithm always adjusts things so you gotta respond right then or you'll never find it again.
-Brad
- 595 Views
Last post by askbob
- 1045 Views
Last post by REMJ666
- 1271 Views
Last post by JosephS
- 2845 Views
Last post by mvelarde890
- 1454 Views
Last post by SoAzRC
- 2116 Views
Last post by bearrickster
- 511 Views
- 665 Views
Last post by XLR8
