Pistons that fit in older TRX shocks?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Hello Friends,
Does anyone know of readily (or not too hardly...) available pistons that work in the old-school (trx-1, Eagle and the likes) traxxas shocks?
The AE pistons are bigger as I found out... the shock bodies are a very similar size outside but the thickness of the body is much higher on the traxxas's, so AE small bore pistons just don't fit...
Thanks in advance,
Paul
Thanks in advance,
Paul
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Re: Pistons that fit in older TRX shocks?
Paul,
Nice to see you pop in here. Hope all is well. Not sure if you do the Amazon thing...but there does seem to be some TRA 1965 availability:
https://www.amazon.com/Traxxas-1965-Shock-Piston-Retainers/dp/B0006O5HIU
- Lonestar
Hi Mark
Thanks for your help - good to see some pillars of the forum still around.
Appreciate the help on 1965's, thanks. My beef with the stock Pistons (which I have in my shocks) is that they have ZERO pack, even with the lowest-size "indent" one... So I was hopeful some more race-oriented branded pistons, where a bit more R&D went into hydraulics, would offer a better option.
worst case, I will try to order some 1965's, fill them up, and redrill, but I'm a lazy b@st@rd
Will post updates to a couple of long-term projects soon - with the local tracks being closed again, I can spend some time on vintage RC stuff
Cheers,
Paul
Cheers,
Paul
Maybe these guys?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fp%2F1700128771
Not sure on diameter. Could maybe turn them or sand them down?
- Lonestar
OooOOOOOoooh.... Shipping is a killer to Europe but this is s e x y ....
Thanks Joe!!!
Thanks Joe!!!
- 1308 Views
Last post by JosephS
- 1810 Views
Last post by RPMfieldtester
- 2387 Views
Last post by radioactivity
- 967 Views
Last post by TRX-1-3
- 1270 Views
Last post by adam lancia
- 1984 Views
Last post by Welshy40
- 1625 Views
Last post by 59burst
- 3088 Views
Last post by Group B
