LosiXX #2
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
LosiXX #2
This car won't be concours quality but it is in fairly nice condition.
Early pics as received...
The motor plate is probably the roughest part so I started there.
Then onto sanding... Only the rear portion seems really bad so I am trying a 2 tone anodize.
More sanding and polishing...
And the anodizing...
Chuck
Chuck
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
Re: LosiXX #2
Wow polishing before anodizing really makes a fantastic difference !
Hey Cru ! Go balls out
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
Re: LosiXX #2
Do you do your own annodizing? That looks great!
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
- radioactivity
Re: LosiXX #2
And that was not the final polishing. To achieve a nice anodize the final polish must be nearly flawless.MarkyDents wrote: ↑Wed Jan 19, 2022 4:19 pm Wow polishing before anodizing really makes a fantastic difference !
This motor plate is not perfect but pretty nice.
Probably had at least 4 or more hours of sanding/polishing, probably far more.
Then another hour or two of prep before anodizing.
In the ano bath for 2 hours.
In the dye bath for 30 min.
In the nickel acetate sealant for 30 min.
Finally 30 min cleaning, a light buff and light oiling.
Chuck
- radioactivity
Re: LosiXX #2
Yep.
I did not go to deeply into the process 'cause it is mostly covered here https://www.rc10talk.com/viewtopic.php?f=30&t=46027
It took me a lot of reading and experimentation and it can be a bit wordy to tell the whole story.
Still trying to learn every time I try.
Chuck
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
Re: LosiXX #2
Amazing result! I have a LOT of parts waiting to go to the anodizer. A lot of them are pieces I have already stripped, and need polishing. You are absolutely right - the polish job determines the anodize result. I really don't enjoy polishing, so it's been very easy to put off sending my parts to the anodizer, lol.
- radioactivity
Re: LosiXX #2
Thanks Lavigna
I initially tried to find a local anodizer but failed. Every one wants to do quantity not quality one offs. Even tried gunsmiths for a hook up, to no avail. Paintball guys might know, haven't tried them.
Now if I had something like 6 Baldor pedestal mounted buffing wheels I could cut the polishing time down a lot. And have a huge mess going on.
Oh well I got time and some patience. I'll stay small scale.
Chuck
Chuck
- radioactivity
Re: LosiXX #2
I had been collecting a few replacement parts for a while.
The bumper and rear pivot support were pretty torn up.
Went ahead and completely cleaned everything.
Got a Boki body and gear cover, new RPM ball ends, wheels , wheel covers and tires.
Chuck
Chuck
- radioactivity
Re: LosiXX #2
The Boki body turned out pretty nice.
Box art-ish but that Faspearl blue spoke to me after the motor plate was anodized.
- radioactivity
Re: LosiXX #2
And after a little more body trimming
And with it's brother
Chuck
Chuck
- MarkyDents
Re: LosiXX #2
Oh man that came out amazing !!
Very well done
Very well done
- Frankentruck
Re: LosiXX #2
Wow. Very period correct styling. Totally rad dude.
- Lavigna
Re: LosiXX #2
Amazing results! Really impressive. Thanks so much for the great thread and pictures.
- Frankentruck
Re: LosiXX #2
Any pics of the cleaned up chassis with the body shell off?
